RPi - AD2USB - Vera3 question
Re: RPi - AD2USB - Vera3 question
Postby xuniman » Fri Sep 05, 2014 11:10 am
I only have 1 partition. Here is the output. If you need more let me know.
[0000000100000000----],015,[f70000011015000008020000000000],"FAULT 15 GARAGE LEFT WINDOW "
[1000000100000000----],008,[f70000040008001c08020000000000],"****DISARMED**** Ready to Arm "
[0000000100000000----],003,[f70000011003000008020000000000],"FAULT 03 DINING WINDOW LEFT "
[0000000100000000----],004,[f70000011004000008020000000000],"FAULT 04 DINING WINDOW RIGHT "
[0000000100000000----],010,[f70000011010000008020000000000],"FAULT 10 SLIDINGDOOR "
[0000000100000000----],013,[f70000011013000008020000000000],"FAULT 13 BACK DOOR "
xuniman
Postby kevin » Fri Sep 05, 2014 11:15 am
Actually, ignore everything I just said... our local panel doesn't do this when there is zone faults. I will have to ask Sean to chime in here when he can.
Are you sure you don't have another partition? Can you post your AD2 configuration? Make sure to include your keypad address mask.
Postby kevin » Fri Sep 05, 2014 11:36 am
According to the messages you do indeed have 2 partitions - this is a common trick from installers, you're lucky that the 2nd one is disarmed otherwise you'd never be able to go into programming mode
If you want to completely ignore that 2nd partition, please change the address filter mask of your ad2 device to only include the addresses of keypads you would like to see.
The address mask of your keypad at address 16 is 00000110 - you can mimic that to ignore the disarmed messages.
Postby xuniman » Fri Sep 05, 2014 12:40 pm
Putting in the mask seems to have fixed it. I had to do it through a Telnet session using the ! console interface. When I tried it in the Web interface settings dialog it didn't save.
If I could figure out how to disable the second partition on my 20P I would. There is nothing programmed to it.
xuniman
Postby kevin » Fri Sep 05, 2014 1:41 pm
The programming manual will help you with that process, it's definitely out of scope for this - but you can remove the partition entirely.
Postby xuniman » Fri Sep 19, 2014 10:40 pm
It seems that I was premature in saying this was fixed. When I used the 00000110 mask I had issues programming. I figured out I needed to change it to a 00000400 mask to allow programming but now I seem to be getting Partition 2 ready to arm messages again. This happens in Web app.
2014-09-20 06:36:45 [0000000100000000----],011,[f70000011011000008020000000000],"FAULT 11 BATHROOM WINDOW "
2014-09-20 06:36:42 [1000000100000000----],008,[f70000040008001c08020000000000],"****DISARMED**** Ready to Arm "
2014-09-20 06:36:41 [0000000100000000----],010,[f70000011010000008020000000000],"FAULT 10 SLIDINGDOOR "
2014-09-20 06:36:37 [0000000100000000----],011,[f70000011011000008020000000000],"FAULT 11 BATHROOM WINDOW "
2014-09-20 06:36:33 [0000000100000000----],010,[f70000011010000008020000000000],"FAULT 10 SLIDINGDOOR "
2014-09-20 06:36:32 [1000000100000000----],008,[f70000040008001c08020000000000],"****DISARMED**** Ready to Arm "
2014-09-20 06:36:29 [0000000100000000----],011,[f70000011011000008020000000000],"FAULT 11 BATHROOM WINDOW "
2014-09-20 06:36:25 [0000000100000000----],010,[f70000011010000008020000000000],"FAULT 10 SLIDINGDOOR "
2014-09-20 06:36:22 [1000000100000000----],008,[f70000040008001c08020000000000],"****DISARMED**** Ready to Arm "
2014-09-20 06:36:21 [0000000100000000----],011,[f70000011011000008020000000000],"FAULT 11 BATHROOM WINDOW "
The 191 Field is programmed as a 10 which should make address 18 keypad part of partition 1. When I asked how to disable Partition 2 in the DIY forum for Ademco they told me that it can't be disabled.
How do I get this fixed?
xuniman
Postby kevin » Sat Sep 20, 2014 2:32 pm
If you can't disable it, then you'll have to find a mask that ignores messages from that partition completely.
