Older AD2USB not sending correctly?
Re: Older AD2USB not sending correctly?
Postby hamw » Fri Oct 16, 2020 7:07 pm
Could you take a sec and post a link to the debug software? I looked all over the site and did not see it. I have monogui running correctly and can upload firmware, if that is how it is done.
Thanks!!
hamw
Postby hamw » Thu Nov 05, 2020 6:37 pm
Here we go. Did not see much diagnostic info come over. However, I did try resetting it a couple of times and also changed the apparent keypad from 31 to 19. I have three keypads and checked the addresses. I did not open a new address on the panel itself but figured it would not take/read if it was not already enabled as you mentioned.f
Next steps? Seems to not be able to send.
[code]Starting AlarmDecoderApp build #2.0.10.23844
11/5/2020 9:24:09 PM Trying to DNS resolve: 127.0.0.1
11/5/2020 9:24:09 PM Trying to connect to: 127.0.0.1:15005
11/5/2020 9:24:10 PM Loding modules. To remove modules use the modules tab under the about menu
11/5/2020 9:24:10 PM Example V1.0 initialized
11/5/2020 9:24:11 PM keypad V1.0 initialized ()
11/5/2020 9:24:11 PM MyStuff V1.0b initialized
11/5/2020 9:24:17 PM Waiting for communication to AlarmDecoder to open
11/5/2020 9:24:19 PM !SER2SOCK Connected
11/5/2020 9:24:19 PM Communicaiton to AlarmDecoder established
11/5/2020 9:24:19 PM Trying to make sure we are not in config mode sending \r\n A Bunch!
11/5/2020 9:24:19 PM Sending '\r\n' to check if in config mode.
11/5/2020 9:24:19 PM !SER2SOCK SERIAL_CONNECTED
11/5/2020 9:24:19 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:24:19 PM !MS> sending alert: AD2USBGUI Alert: mystuff initialized: DISARMED READY
11/5/2020 9:24:19 PM !RFX:0057342,fe
11/5/2020 9:24:19 PM !>RESET=Y
11/5/2020 9:24:19 PM Found config line clearing and wait again.
11/5/2020 9:24:19 PM !CONFIG>ADDRESS=31&CONFIGBITS=ff04&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
11/5/2020 9:24:19 PM !RFX:0219646,fe
11/5/2020 9:24:22 PM The AlarmDecoder not in config mode. Continuing to initialize.
11/5/2020 9:24:23 PM Sending 'V' command to the AlarmDecoder
11/5/2020 9:24:23 PM !VER:ffffffff,V2.2a.6,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB
11/5/2020 9:24:23 PM Found Version String
11/5/2020 9:24:32 PM !Sending......done
11/5/2020 9:24:32 PM Sending 'C' command to the AlarmDecoder
11/5/2020 9:24:32 PM Timeout waiting for !CONFIG> message from the AlarmDecoder
11/5/2020 9:24:32 PM Sending '\r\n' command to the AlarmDecoder
11/5/2020 9:24:32 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:24:32 PM !>
11/5/2020 9:24:32 PM !CONFIG>ADDRESS=31&CONFIGBITS=ff04&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
11/5/2020 9:24:36 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:24:48 PM !Sending......done
11/5/2020 9:24:48 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:24:48 PM !RFX:0262364,18
11/5/2020 9:25:01 PM !Sending......done
11/5/2020 9:25:01 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:25:11 PM !Sending......done
11/5/2020 9:25:11 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:25:20 PM !RFX:0018516,04
11/5/2020 9:25:48 PM !>RESET=Y
11/5/2020 9:25:48 PM !CONFIG>ADDRESS=31&CONFIGBITS=ff04&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
11/5/2020 9:25:55 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:27:02 PM !>ADDRESS=19&EXP=nnnnn&REL=nnnn&LRR=N&DEDUPLICATE=Y
11/5/2020 9:27:02 PM !setting ADDRESS 19
11/5/2020 9:27:02 PM !setting EXPANDER emulation NNNNN
11/5/2020 9:27:02 PM !setting RELAY emulation NNNN
11/5/2020 9:27:03 PM !setting LRR emulation OFF
11/5/2020 9:27:03 PM !>setting DEDUPLICATE ON
11/5/2020 9:27:03 PM !CONFIG>ADDRESS=19&CONFIGBITS=ff04&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
11/5/2020 9:27:04 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:28:12 PM !>ADDRESS=19&EXP=nnnnn&REL=nnnn&LRR=N&DEDUPLICATE=Y
11/5/2020 9:28:12 PM !setting ADDRESS 19
11/5/2020 9:28:12 PM !setting EXPANDER emulation NNNNN
11/5/2020 9:28:12 PM !setting RELAY emulation NNNN
11/5/2020 9:28:12 PM !setting LRR emulation OFF
11/5/2020 9:28:13 PM !>setting DEDUPLICATE ON
11/5/2020 9:28:13 PM !CONFIG>ADDRESS=19&CONFIGBITS=ff04&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
11/5/2020 9:28:14 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:29:07 PM !>
11/5/2020 9:29:07 PM !CONFIG>ADDRESS=19&CONFIGBITS=ff04&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
11/5/2020 9:29:11 PM !>
11/5/2020 9:29:11 PM !CONFIG>ADDRESS=19&CONFIGBITS=ff04&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
11/5/2020 9:29:13 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:29:14 PM !>ADDRESS=19&EXP=nnnnn&REL=nnnn&LRR=N&DEDUPLICATE=Y
11/5/2020 9:29:14 PM !setting ADDRESS 19
11/5/2020 9:29:14 PM !setting EXPANDER emulation NNNNN
11/5/2020 9:29:14 PM !setting RELAY emulation NNNN
11/5/2020 9:29:14 PM !setting LRR emulation OFF
11/5/2020 9:29:14 PM !>setting DEDUPLICATE ON
11/5/2020 9:29:14 PM !CONFIG>ADDRESS=19&CONFIGBITS=ff04&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
11/5/2020 9:29:23 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:30:39 PM !Sending......done
11/5/2020 9:30:39 PM !RFX:0262364,9e
11/5/2020 9:30:39 PM !EX> Item List changed name: 0262364 id: 262364
11/5/2020 9:30:47 PM !Sending......done
11/5/2020 9:30:47 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:30:47 PM !RFX:0099164,9e
11/5/2020 9:31:12 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:31:42 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:33:00 PM !>Diag. Flag (48) :
11/5/2020 9:33:00 PM >48
11/5/2020 9:33:01 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:33:22 PM !Sending......done
11/5/2020 9:33:22 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:33:30 PM !Sending......done
11/5/2020 9:33:38 PM !Sending......done
11/5/2020 9:33:38 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:33:46 PM !Sending......done
11/5/2020 9:33:46 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "
11/5/2020 9:33:47 PM !RFX:0262364,7e
11/5/2020 9:33:47 PM !EX> Item List changed name: 0262364 id: 262364
11/5/2020 9:33:47 PM !RFX:0099164,7e
11/5/2020 9:33:47 PM !EX> Item List changed name: 0099164 id: 99164
11/5/2020 9:33:56 PM [0000000100000000----],008,[f70000ff1008000c08020000000000],"****DISARMED****Hit * for faults"
11/5/2020 9:34:04 PM !Sending......done
11/5/2020 9:34:04 PM [1000000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED**** Ready to Arm "/code]
hamw
Postby hamw » Fri Nov 06, 2020 2:19 pm
!SER2SOCK Connected
@48
!>Diag. Flag (0) :>48
!Sending.done
[1001000100000000----],008,[f70000ff1008001c08020000000000],"****DISARMED****  Ready to Arm  "
C
V
Helpful?
hamw
Postby hamw » Sun Nov 08, 2020 10:31 am
Well, good news and we can put it to bed. There was nothing wrong with the AD2USB or the wiring or the panel. I did need to enable a keypad, and also enabled quick arm.
The issue was that I am using Indigo home automation software to control the panel. When I replaced the 20SE with the 20p, I continued with the same Indigo plugin that had worked with the 20SE. So, somehow the plugin would not recognize that it was seeing a new panel, and what must be a hard setting in the plugin's preferences was forcing address 31 or some other wonky behavior. I replaced that plugin with a fresh copy, reset it all and then voila it is now communicating and working as expected.
Thanks for the help ... maybe my experience might help someone else.
hamilton
hamw
