Hit * for faults - multi-partition
Re: Hit * for faults - multi-partition
Postby mathewss » Mon Sep 13, 2021 9:49 am
A few ideas yes.
If you can turn on debugging by sending @48 then type your K command and send me 30 or so lines of messages from the AD2* when this is done.
1) Another keypad is at 19
2) 19 is not enabled on the partition that has a fault.
A few lines of messages from the panel so I can see the keypads that are enabled would help and again above the debug dump while sending will show if another keypad is on that same address.
will look something like this. This was me sending K01 to my 50PUL panel.
[01010001000100003A--],0fc,[f700000000fc804c0c020000202020],"SYSTEM LOBAT                    "
!DBG:<ff><ff><ff><ff><ff>
!DBG:*f7*[f7][07][00][16][00][fc][80][0c][0c][02][00][00][c1][52][4d][45][44][20][2a][2a]
!DBG:[2a][41][57][41][59][2a][2a][2a][2a][2a][20][41][4c][4c][20][53][45][43][55][52][45]
!DBG:[20][2a][2a][77]<ff>
[01010001000000003A--],0fc,[f707001600fc800c0c0200002a2a2a],"ARMED ***AWAY***** ALL SECURE **"
!DBG:<ff><ff><ff><ff><ff><ff><ff>
!DBG:*f7*[f7][00][00][00][00][fc][80][0c][0c][02][00][00][d3][59][53][54][45][4d][20][4c]
!DBG:[4f][42][41][54][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20]
!DBG:[20][20][20][fc]<ff>
[01010001000000003A--],0fc,[f700000000fc800c0c020000202020],"SYSTEM LOBAT                    "
!DBG:<ff><ff><ff>
!Sending.!DBG:(fd)<ff>
!DBG:*f6*[f6][01](01)(02)(0a)(f3)[01]done
!DBG:<ff>
!DBG:*f7*[f7][07][00][16][00][fc][80][00][0c][02][00][00][c3][4f][4d][4d][2e][20][46][41]
!DBG:[49][4c][55][52][45][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20]
!DBG:[20][20][20][00]
Postby miragejb » Mon Sep 13, 2021 10:03 am
Here you go. Also, how do you turn off debugging?
!DBG:<ff><ff><ff><ff><ff><ff><ff><ff>(fb)<ff>
!DBG:*f6*[f6][02](62)(0c)(00)(69)(62)(02)(45)(43)(f5)(31)(fb)(43)(6c)(6d)[62]<ff>
!DBG:*f2*[f2][0e][04][00][00][00][00][51][fe][fe][ec][01][01][01][01][bf]<ff><ff><ff><ff>
!DBG:<ff><ff><ff>
!DBG:*f7*[f7][00][00][08][00][08][00][0c][08][02][00][00][2a][2a][2a][2a][44][49][53][41]
!DBG:[52][4d][45][44][2a][2a][2a][2a][48][69][74][20][2a][20][66][6f][72][20][66][61][75]
!DBG:[6c][74][73][c5][00][00][00]<ff>
[00000001000000003A--],008,[f70000080008000c08020000000000],"****DISARMED****Hit * for faults"
!DBG:<ff>
!Sending.!DBG:(ff)(ff)(fe)<ff>
!DBG:*f6*[f6][10](d0)(02)(0a)(24)[d0]done
!DBG:<ff>
!DBG:*f2*[f2][12][26][00][00][00][00][64][6c][02][45][6c][f5][ec][01][01][01][00][00][6f]
!DBG:<ff>
!DBG:*f7*[f7][26][00][03][10][08][00][1c][08][02][00][00][aa][2a][2a][2a][44][49][53][41]
!DBG:[52][4d][45][44][2a][2a][2a][2a][20][20][52][65][61][64][79][20][74][6f][20][41][72]
!DBG:[6d][20][20][d1][00][00][00]
[10010001000000003A--],008,[f72600031008001c08020000000000],"****DISARMED****  Ready to Arm  "
!DBG:<ff>
!DBG:*f2*[f2][16][26][00][00][00][00][65][63][02][45][43][f5][31][fb][45][6c][f5][ec][01]
!DBG:[01][01][01][c9]<ff>(f9)<ff>
!DBG:*f6*[f6][01](21)(0c)(00)(6e)(62)(02)(45)(43)(f5)(31)(fb)(43)(6c)(a9)[21]<ff>(db)<ff>
!DBG:*f2*[f2][0e][02][00][00][00][00][56][fe][fe][ec][01][01][01][01][bc]<ff>
!DBG:*f6*[f6][02](a2)(0c)(00)(6a)(62)(02)(45)(43)(f5)(31)(fb)(43)(6c)(2c)[a2]<ff>(df)<ff>
!DBG:*f2*[f2][0e][04][00][00][00][00][52][fe][fe][ec][01][01][01][01][be]<ff>
!DBG:*f6*[f6][05](e5)(07)(00)(69)(6b)(02)(43)(43)(b8)[e5]<ff>
!DBG:*f2*[f2][0e][20][00][00][00][00][51][fe][ec][01][01][01][00][00][a2]<ff><ff>(df)<ff>
!DBG:*f6*[f6][05](25)(0c)(00)(6a)(62)(02)(45)(43)(f5)(31)(fb)(43)(6c)(a9)[25]<ff>
!DBG:*f2*[f2][0e][20][00][00][00][00][52][fe][fe][ec][01][01][01][01][a2]<ff><ff><ff><ff>
!DBG:<ff>(fd)<ff>
!DBG:*f6*[f6][01](61)(07)(00)(6f)(6b)(02)(43)(43)(36)[61]<ff>
!DBG:*f2*[f2][0e][02][00][00][00][00][57][fe][ec][01][01][01][00][00][ba]<ff>(fd)<ff>
!DBG:*f6*[f6][01](a1)(0c)(00)(68)(62)(02)(45)(43)(f5)(31)(fb)(43)(6c)(2f)[a1]<ff>
!DBG:*f2*[f2][0e][02][00][00][00][00][50][fe][fe][ec][01][01][01][01][c2]<ff><ff><ff><ff>
!DBG:<ff><ff><ff><ff><ff><ff>(fd)<ff>
miragejb
Postby miragejb » Mon Sep 13, 2021 10:04 am
Here you go. Keypad 19 is on and is a valid keypad used on my partition #2. Also, how do you turn off debugging?
!DBG:<ff><ff><ff>
!DBG:<ff>
!DBG:<ff>
!DBG:<ff>
!DBG:<ff>
!DBG:<ff>(fd)<ff>
miragejb
Postby miragejb » Fri Sep 17, 2021 6:29 am
Did you see anything wrong with this? Thanks.
miragejb
Postby kd7mlg » Sun Sep 19, 2021 12:10 pm
@mathewss
I've been having almost exactly the same issue from time to time, and what I've noticed is that if I execute K19*<return> the "*" gets sent from address 18 based on keypad messages.
If I do K19(number)* it transmits the * as coming from keypad address 19.
This is pretty reproducible. I don't have debug logs for the last time I had to do this but I do have logs from ser2sock.
kd7mlg
Postby kd7mlg » Sun Sep 19, 2021 12:11 pm
miragejb wrote:Also, how do you turn off debugging?
@00<enter>
kd7mlg
Postby miragejb » Thu Sep 23, 2021 4:29 am
Will this fix my problem? If so, could you give me an example of what the "number" substitute you have in the above statement might be and what it represents?
miragejb
Postby kd7mlg » Fri Sep 24, 2021 7:16 pm
I can't say that it will "fix" your problem but it may work as a workaround.
To answer your question by example, when I send 'K19*' the '*' doesn't get sent from Keypad Address 19. But if I send 'K195555*' (four 5s) then it seems to transmit from keypad address 19. I haven't done any kind of testing to see if fewer digits work or not but it seems reasonable to think that may work.
kd7mlg
Postby miragejb » Tue Sep 28, 2021 12:24 pm
I just figured it out. For some reason, it doesn't like me using a live keypad that is connected to the panel.
I enabled another keypad device address on the panel and assigned it to partition 2 (No physical keypad). If I use this address, then I can type in "K19*" and everything works fine.
Thanks for your help.
miragejb
