Example site? Password protected?
Re: Example site? Password protected?
Postby Maxburn » Sun Mar 29, 2015 8:24 am
OK, but it doesn't quite look like it's going to do it. That did get me to the login screen, BUT after logging in I get this error
400 Bad Request
The plain HTTP request was sent to HTTPS port
nginx/1.7.7
The error in the log is this:
2015/03/29 21:00:23 [error] 2454#0: *131 open() "/opt/alarmdecoder-webapp/ad2web/static/css/user_custom.css" failed (2: No such file or directory), client: 10.0.1.20, server: , request: "GET /static/css/user_custom.css HTTP/1.1", host: "10.0.1.30", referrer: "h$
For the record I found the server conf block in /etc/nginx/sites-enabled/alarmdecoder
Maxburn
Postby kevin » Mon Mar 30, 2015 9:14 am
Will have to play around with this in the office and see what's going on - should be that simple.
As far as that custom css file not being found - you can ignore that error - that file is loaded by the webapp if it exists, if not, then it doesn't care - it's a file you can create to override styles to your own preferences.
Postby Gordon » Sun Apr 12, 2015 9:16 am
kevin wrote:Will have to play around with this in the office and see what's going on - should be that simple.
Oh so I wish!.. been playing around with the config for a few hours now and making very little progress.
Interestingly. when I switched to IE from Chrome, I did get a login screen (since I guess my login was not cached) on port 443 (HTTPS) but once logged in I got the same error message, " 400 Bad Request - The plain HTTP request was sent to HTTPS port"
So.. bump! Hoping to get some help to get HTTPS working
Gordon
Postby mathewss » Sun Apr 12, 2015 9:32 am
Sounds like an easy fix inside of NGINX..
Check your server section(s) please send us a copy of your config here.
Here is an example using 2 server sections one for SSL and one for NON SSL
server {
  listen 80;
  // other directives...
server {
  listen 443;
  ssl on;
  // SSL directives...
or you can combine them
server {
  listen 80;
  listen 443 default ssl;
  # ssl on   - remember to comment this out if you have it active
Postby Maxburn » Sun Apr 12, 2015 10:25 am
Again I'm not the expert at this stuff but there seems to be a reverse proxy going on, if that's the right term? The actual alarm decoder page contents after login appear to be coming from this section of the config file:
    location @alarmdecoder {
        proxy_pass http://127.0.0.1:5000;
So whatever server is on that port needs to handle SSL too I'd guess? No idea why it's done that way but if you pull up the web page on that port it's the same page. I'm not sure if it's even a good idea to have the web server on the pi serving an undocumented port from a security standpoint.
Maxburn
Postby Gordon » Sun Apr 12, 2015 11:07 am
Just to be clear.. and perhaps correct my error, we are talking about this config file, right?
Gordon
Postby Maxburn » Sun Apr 12, 2015 11:18 am
Seems there are three config files spelled out. Nginx first looks at the nginx.conf which happens to have this in it:
        include /etc/nginx/conf.d/*.conf;
        include /etc/nginx/sites-enabled/*;
There doesn't appear to be anything in my conf.d folder though. So looks like the whole nginx configuration is spread through two files.
Maxburn
Postby Gordon » Sun Apr 12, 2015 2:14 pm
Tried a lot of variations.. this is one
file: /etc/nginx/sites-enabled/alarmdecoder
This should be the same as the original as installed except for the addition of these lines:
ssl_certificate /etc/nginx/ssl/nginx.crt;
ssl_certificate_key /etc/nginx/ssl/nginx.key;
I'll add another possible clue.. in IE, I get a partial display with the menu,
Logged in .. Please Wait Loading... etc. and IE warns that only the secure content is displayed. Choose to display all content (or reload) and the "The plain HTTP request was sent to HTTPS port" message comes up. There is no error message in /var/log/nginx/error.log (except the aforementioned css error).
server {
    listen 80;
    error_page 502 /502.html;
    gzip on;
    gzip_disable "msie6";
    gzip_vary on;
    gzip_proxied any;
    gzip_comp_level 6;
    gzip_buffers 16 4k;
    gzip_http_version 1.1;
    gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript;
    location / {
        try_files $uri @alarmdecoder;
        include uwsgi_params;
        uwsgi_param UWSGI_SCHEME $scheme;
        uwsgi_param SERVER_SOFTWARE nginx/$nginx_version;
        proxy_redirect off;
        proxy_http_version 1.1;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "upgrade";
        proxy_set_header Host $host:$server_port;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Host $server_name;
    location /502.html {
        root /opt/alarmdecoder-webapp/ad2web/static;
    location ~ \.(jpg|jpeg|png|css|js)$ {
    root /opt/alarmdecoder-webapp/ad2web;
Gordon
Postby kevin » Mon Apr 13, 2015 9:41 am
Hey guys, I was able to get this working in our demo lab with minimal changes to ONLY the nginx configuration file (/etc/nginx/sites-enabled/alarmdecoder)
Here is ours for example:
server {
   listen 80;
   return 301 https://$host$request_uri;
server {
    listen 443 ssl;
    server_name alarmdecoder-demo;
    ssl_certificate /etc/nginx/cert.crt;
    ssl_certificate_key /etc/nginx/cert.key;
    ssl on;
    ssl_session_cache builtin:1000 shared:SSL:10m;
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
    ssl_ciphers HIGH:!aNULL:!eNULL:!EXPORT:!CAMELLIA:!DES:!MD5:!PSK:!RC4;
    ssl_prefer_server_ciphers on;
    gzip on;
    gzip_vary on;
    gzip_proxied any;
    gzip_comp_level 6;
    gzip_buffers 16 4k;
    location / {
        proxy_redirect off;
          proxy_set_header X_FORWARDED_PROTO https;
   proxy_redirect http://localhost:5000 https://alarmdecoder-demo;
Feel free to use this for example or ask questions - this particular config forces always HTTPS connections - the key lines were:
server block:
@alarmdecoder block:
Postby Gordon » Mon Apr 13, 2015 12:46 pm
@ Kevin
Thanks, works great now with Chrome browser (after changing to match my SSL files and path)... Great customer service again!
But note that using IE-11 the behavior is still exactly as I described above. Did you try IE?
Also saw this on restart:
pi@alarmdecoder ~ $ sudo service nginx restart
Restarting nginx: nginx: [warn] conflicting server name "" on 0.0.0.0:80, ignored
nginx.
Might have spoke too soon.. seems to be back to the same problem, even after restarting chrome and clearing cache.. still testing,, will post update later.
Gordon
PreviousNext
