Services might still be starting... Forever
Re: Services might still be starting... Forever
Postby Scott » Tue Mar 24, 2015 3:02 pm
Those cert names are auto generated, so that shouldn't be the issue.
Postby Maxburn » Tue Mar 24, 2015 4:06 pm
Thank you for your assistance, it's back up and running again. And yes, I don't remember selecting names for the certificates.
I'll tackle moving the webapp over to SSL for what tiny little protection that offers some other time but first I think I'll investigate a way to back up/image the SD card somehow.
Thanks again.
Maxburn
Postby kevin » Tue Mar 24, 2015 4:29 pm
You will just need to backup an image of your SD Card
For Windows you can use Win32 Disk Imager
For Linux, you can use the "dd" utility - sudo dd if=<device> of=saved_image_filename.img bs=4M where <device> is the device name of the sdcard (/dev/sd...) - you can find this with a 'dmesg' when inserting the SD Card via an SD Card reader.
Postby Maxburn » Tue Mar 24, 2015 4:38 pm
I'll look into it, thanks again.
Maxburn
Users browsing this forum: No registered users and 51 guests
