AD2PI with PC1616
Re: AD2PI with PC1616
Postby kevin » Wed Jul 01, 2015 12:59 pm
Is this a B+ model? Not the quad core model? Yes, the CPU on that model is not quite suited for this task, the quad core performs much better.
Postby intellix » Wed Jul 01, 2015 9:23 pm
Thanks Kevin,
I never checked model version....just took the nearest available pi I had. It seems I am using the B model revision 000E.
Get back with results once I've changed to newer board.'
/Gerry
intellix
Postby intellix » Thu Jul 02, 2015 7:45 am
A quick update:
I have installed Alarmdecoder on a raspberry pi 2.
Following the setup procedure...setting it to DSC...worked directly
Made the necessary changes to get the CAMs working......impressed!
Once you click on a cam tag, it shows the latest still image with about 1 sec delay.
Now what I will need assistance with...:
when DSC alarm is armed and a DSC specific zone activates - alarmdecoder gets a series of still images from specified camera nbr - saves to sd card - emails to a predetermined list.
/Gerry
intellix
Postby kevin » Thu Jul 02, 2015 9:11 am
We are planning on expanding the notification system to integrate cameras that detect a face - as for now, it is just a convenient portal to watch your cameras and alarm in the same interface. If you have custom buttons defined, these will appear on the cameras page as well - so you can define a custom panic button for instance, and if something you see on the cameras you don't like, you can hit the button to activate the alarm for example.
Users browsing this forum: No registered users and 56 guests
