AD2Pi & DSC PC1616 -Worked, now browser gets 502 Bad Gateway
Re: AD2Pi & DSC PC1616 -Worked, now browser gets 502 Bad Gat
Postby wilsonb » Mon Jul 27, 2015 5:22 pm
Do you see any problems with installing tightvncserver, synaptic, tmux ?
wilsonb
Postby kevin » Mon Jul 27, 2015 5:30 pm
wilsonb wrote:Do you see any problems with installing tightvncserver, synaptic, tmux ?
synaptic is just a frontend for apt, I would avoid it.
I don't see issues with really installing new things, as long as they aren't modifying existing packages.
Postby wilsonb » Mon Jul 27, 2015 9:45 pm
This 502 Bad Gateway - Certificate invalid issue came back on a vanilla system while in IE. Deleted cach, temp, cookies, etc
Seems to get it working again. The tab still says Certificate Invalid , but its working again.
wilsonb
Postby kevin » Tue Jul 28, 2015 10:06 am
The certificate invalid error is only because it is a self-signed certificate - meaning it's not signed by a trusted certificate authority. Your browser will let you know about it, but it's perfectly safe and encrypted.
Also, you're using IE? I don't recommend that at all for anything.
Postby wilsonb » Tue Jul 28, 2015 10:53 am
IE is definitely my last choice of browsers.. I was just using it because it seems to be the defacto for Webapps in the past. Like Foscam company for some reason builds everything off IE.. terrible.
I personally use Firefox.
wilsonb
Postby kevin » Tue Jul 28, 2015 10:54 am
Well, I can tell you that we barely support IE and it is an afterthought for us. Suggest not using it at all.
Postby wilsonb » Tue Aug 04, 2015 11:52 am
End result when getting errors like this.
Try going into browser settings and delete everything... :shock:
At least that is working for me in different browsers.
wilsonb
Users browsing this forum: No registered users and 288 guests
