Noticing slow return communication from webapp
Re: Noticing slow return communication from webapp
Postby kevin » Fri Aug 07, 2015 10:31 am
You don't have to delete and recreate these notifications, you can:
stop gunicorn
backup your database
start gunicorn
delete notification
test
stop gunicorn
restore backed up database
start gunicorn
This will put you back to where the notifications are in place again.
Also, your info.log will show us if you have a ton of events firing when they shouldn't be or too often, please post this as well.
Postby wilsonb » Fri Aug 07, 2015 10:45 am
Exported settings -
Deleted all Notification and restarted Pi.
Still about 5-6 Sec delay when using GUI, refresh and response delayed.
When clicking on Menu items, when arming/disarming, etc..
wilsonb
Postby kevin » Fri Aug 07, 2015 10:53 am
Strange to see, don't see these issues here. If you can post your info.log to see if there are strange events going on that would be great.
Are you running ser2sock in SSL mode ?
Postby wilsonb » Fri Aug 07, 2015 11:08 am
How can I check this?
"Are you running ser2sock in SSL mode ?"
wilsonb
Postby kevin » Fri Aug 07, 2015 11:10 am
Post your /etc/ser2sock/ser2sock.conf
Postby wilsonb » Fri Aug 07, 2015 11:12 am
[ser2sock]
daemonize = 1
device = /dev/ttyAMA0
baudrate = 115200
port = 10000
raw_device_mode = 1
preserve_connections = 1
bind_ip = 0.0.0.0
send_terminal_init = 0
device_open_delay = 5000
encrypted = 0
ca_certificate =
ssl_certificate =
ssl_key =
ssl_crl = /etc/ser2sock/ser2sock.crl
wilsonb
Postby kevin » Fri Aug 07, 2015 11:15 am
Hmm, negative on that. Really need that info.log to see the events. Do you have cameras defined at all? Or are you just using your notifications for your cameras?
Postby wilsonb » Fri Aug 07, 2015 11:19 am
Actually, I did have three cameras defined under camera view. I deleted those and walaa.. Works smooth as butter.
I will stay away from Administrate Camera section in menu.
Might be the case with others if they use that feature.
Cheers
wilsonb
Postby kevin » Fri Aug 07, 2015 11:21 am
Absolutely is the case - that code uses a lot of CPU. Known issue here, I had just assumed you weren't using it since you were triggering your cameras manually via notifications.
Postby wilsonb » Fri Aug 07, 2015 12:41 pm
Sorry, I should have mentioned all my settings.
wilsonb
Users browsing this forum: No registered users and 4 guests
