VERA 20p and ALARMDECODER APPLIANCE
Re: VERA 20p and ALARMDECODER APPLIANCE
Postby jplouch » Thu Jan 11, 2018 9:56 pm
address is set to 18 already
jplouch
Postby kevin » Thu Jan 11, 2018 9:57 pm
Then I can only guess that address 18 is not enabled on the panel or the wiring is loose or there is already a keypad at address 18
Postby jplouch » Thu Jan 11, 2018 9:58 pm
it is enabled I will change the address and try the and let you know
jplouch
Postby jplouch » Thu Jan 11, 2018 10:18 pm
well i changed it to address 19 and it still does not work...... on the alarm pad i hit *192 and then 02. that should change it correct? do you know the diff between 00,01,and 02? it weird because it was working so i assume adt did something
jplouch
thank you for your patience!!!
jplouch
Postby kevin » Thu Jan 11, 2018 10:19 pm
Sorry, I'm not sure - you'll have to email support - ad2usb@support.nutech.com
Users browsing this forum: No registered users and 56 guests
