Ad2 web app issues
Re: Ad2 web app issues
Postby danimal1228 » Thu Jul 03, 2014 10:22 am
My pi does many things other than running the ad2pi so I couldn't use the image. I installed it from scratch based on the instructions in the readme. It works perfect via the Mac and safari.
I have tested it with both the iPad and iPhone over wifi and VPN. Problem persists.
Ill check port 10000 when I get a chance.
Thanks again.
danimal1228
Postby kevin » Thu Jul 03, 2014 12:20 pm
One difference could be the IOS version. Ours is IOS 7 and we have not had a chance to work with IOS 6, there might be some differences that need to be addressed, but looking at support for things we use such as websockets it all seems to be supported. But that doesn't mean all the javascript and such we are doing is compatible - needs to be investigated.
Postby mathewss » Thu Jul 03, 2014 12:24 pm
danimal1228 wrote:My pi does many things other than running the ad2pi so I couldn't use the image. I installed it from scratch based on the instructions in the readme. It works perfect via the Mac and safari.
Thanks again.
With the 30 second delay to load the page on Mac safari this is still a failure that is not happening on other installs both our canned image or from our steps.
Things to check.
1. what is the CPU load.
2. Do you have any other processes using the /dev/ttyUSBXX for the AD2Pi at the same time? this could cause the problem you are seeing where another processes is stealing the messages from the port.
Connection via port 10000 using putty and not seeing a steady stream of messages would be the best test to confirm that the lower level communication is working properly so we could focus on other areas that may cause this behavior.
Users browsing this forum: No registered users and 29 guests
