Need help with webapp update
Re: Need help with webapp update
Postby pyrodex » Mon Mar 07, 2016 11:06 am
Here is mine. Yes I did clear mine and even did a private session in chrome.
https://dl.dropboxusercontent.com/u/207349/logs.tar.gz
I am still stuck in /setup/test and can't get past it now.
pyrodex
Postby kevin » Mon Mar 07, 2016 11:54 am
Can you post the nginx version you have installed? (nginx -v)
Postby kevin » Mon Mar 07, 2016 11:55 am
pyrodex wrote:Here is mine. Yes I did clear mine and even did a private session in chrome.
Please remove and reinitialize your database and go through setup again
cd /opt/alarmdecoder-webapp
sudo rm instance/db.sqlite
python manage.py initdb
sudo /etc/init.d/gunicorn restart
Postby JJsLegacy » Mon Mar 07, 2016 12:36 pm
root@ncalarm:/opt/alarmdecoder-webapp# nginx -v
nginx version: nginx/1.2.1
seems old but that's what was in your pi bundle software
JJsLegacy
Postby pyrodex » Mon Mar 07, 2016 12:38 pm
kevin wrote:Can you post the nginx version you have installed? (nginx -v)
Fixed the setup issue with DB commands.
Here is the version:
pi@alarmdecoder /opt/alarmdecoder-webapp $ nginx -v
pyrodex
Postby Scott » Mon Mar 07, 2016 12:49 pm
Okay that nginx version totally explains a lot! It doesn't support websockets.
There was an incorrect package hold in our last raspbian image. Doing an apt-get upgrade causes it to upgrade nginx even though we're newer. For whatever reason raspbian doesn't ship current versions of nginx in their package repositories. I have a new image in the works, but it probably won't be out till late this week or early next.
This should fix you up with our last release:
1. sudo apt-get -y remove nginx nginx-full
2. sudo apt-get clean
3. VERSION=1.7.4
4. curl http://nginx.org/download/nginx-$VERSION.tar.gz | tar zxvf -
5. cd nginx-$VERSION
6. ./configure --sbin-path=/usr/sbin/nginx --conf-path=/etc/nginx/nginx.conf --pid-path=/var/run/nginx.pid --error-log-path=/var/log/nginx/error.log --http-log-path=/var/log/nginx/access.log --with-http_ssl_module --with-ipv6
7. make
8. sudo make install
9. sudo sync && sudo reboot && exit
Fingers crossed!
Postby pyrodex » Mon Mar 07, 2016 12:59 pm
Scott wrote:Okay that nginx version totally explains a lot! It doesn't support websockets.
3. VERSION=1.7.4
7. make
Fingers crossed!
Step three needs an export :)
pyrodex
Postby JJsLegacy » Mon Mar 07, 2016 1:03 pm
No export needed for that.
I was actually already working down that path as I saw on the github 1.7.4 and higher required.
Good news - all looks good now!
Thanks guys!
JJsLegacy
Postby Scott » Mon Mar 07, 2016 1:10 pm
Awesome, glad to hear it! Sorry for the hassle. =)
Postby pyrodex » Mon Mar 07, 2016 1:46 pm
After the nginx upgrade I am able to get further in the diagnostics from the original full webpage. Now I get an error in Keypad communication (Receive) but the others all check out Green. Keypad is still stuck at loading both on full interface and port 5000 now.
pyrodex
PreviousNext
