Idiots install guide (20p, AD2pi, raspi zero, & SmartThings)
Re: Idiots install guide (20p, AD2pi, raspi zero, & SmartThi
Postby jensen18 » Sun Feb 04, 2018 7:19 pm
I reimaged my card and started over just to see if I did something wrong. Prior to starting step 27 I had 5.9G free. I still ran into an out of space error:
26f8c53f3113: Download complete
b97e5a7a66ae: Error downloading dependent layers
Error pulling image (latest) from docker.io/alarmdecoder/alarmdecoder, symlink ../init.d/mountall.sh /var/lib/docker/overlay/b97e5a7a66ae0877b3d8c394d3ff49a5660e43e456957b88c0b3b550ebcaa5ef/tmproot390715982/etc/rcS.d/S08mountall.sh: no space left on device
Failed to pull alarmdecoder image...
Afterward I checked the file system and there was still 4.4G available. I don't understand how I am getting no space errors.
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.3G 2.6G 4.4G 38% /
devtmpfs 213M 0 213M 0% /dev
tmpfs 218M 0 218M 0% /dev/shm
tmpfs 218M 3.1M 215M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 218M 0 218M 0% /sys/fs/cgroup
/dev/mmcblk0p1 41M 21M 21M 51% /boot
tmpfs 44M 0 44M 0% /run/user/1000
jensen18
Postby jensen18 » Sun Feb 04, 2018 7:52 pm
if I run ./pull.sh again I get two errors in the log but both look to be attributed to the same file:
447bfee15a85: Error pulling image (latest) from docker.io/alarmdecoder/alarmdecoder, symlink /usr/share/man/man8/rmt-tar.8.gz /var/lib/docker/overlay/b97e5a7a66ae0877b3d8c394d3ff49a5660e43e456957b88c0b3b550ebcaa5ef/tmproot059390875/etc/alternatives/rmt.8.gz: no space left on device ernatives/rmt.8.gz: no space left on device d complete
Is there any way I can manually load/install /usr/share/man/man8/rmt-tar.8.gz?
I've rebooted. Now every time I re run ./pull.sh I get the same error message:
Error pulling image (latest) from docker.io/alarmdecoder/alarmdecoder, Driver overlay failed to create image rootfs b97e5a7a66ae0877b3d8c394d3ff49a5660e43e456957b88c0b3b550ebcaa5ef: mkdir /var/lib/docker/overlay/b97e5a7a66ae0877b3d8c394d3ff49a5660e43e456957b88c0b3b550ebcaa5ef: no space left on device
where would I find the /var/ directory referenced above? I want to see if I can make the directory manually.
jensen18
Postby jensen18 » Sun Feb 04, 2018 8:00 pm
ok - I found the /var/lib/ directory, however I cannot get into the docker folder as permission is denied:
drwx------ 8 root root 4096 Feb 5 03:42 docker
I think I have gone as far as I can go....
jensen18
Postby AndyFrew » Fri Dec 28, 2018 9:05 am
Hello...I am trying to add some automation using a contact sensor that is connected to the alarm system, but there is over a 30 second delay until the sensor is shown as open in Smartthings. If I go to the alarm app on the Smartthings app and hit refresh then the sensor will immediately show open.
one-stop pcb assembly services
AndyFrew
Postby mathewss » Fri Dec 28, 2018 3:28 pm
Can you confirm if you are using the old "smartthings" notification on our web app or the new upnp notification?
I ask this because the old plugin used a timer and a "pull" and that took a long time to update. The new way is "usually" a few seconds or less. Sometimes if the SmartThings cloud is busy it can take 5 seconds but not 30.
