AlarmDecoder object has no attribute 'on_ready_changed'
Postby miragejb » Tue Sep 04, 2018 11:46 am
Today I did a fresh install of the alarmdecoder-webapp via docker as described (https://github.com/nutechsoftware/alarmdecoder-docker). My OS is Raspbian stretch.
After installing the OS, docker and the alarmdecoder-webapp, everything was running fine -- no problems at all. One the webapp's home page, I noticed there were some updates available and I installed them.
After installing the updates, I got the "Services might still be starting" page. I tried everything I know how to get it to work.
When I inspected the webapp's log on the docker volume, I noticed that this message kept repeating over-and-over:
2018-09-04 19:00:18,423 INFO: Attempting to reconnect to the AlarmDecoder [in /opt/alarmdecoder-webapp/ad2web/decoder.py:533]
2018-09-04 19:00:18,504 ERROR: Error in DecoderThread: 'AlarmDecoder' object has no attribute 'on_ready_changed' [in /opt/alarmdecoder-webapp/ad2web/decoder.py:549]
File "/opt/alarmdecoder-webapp/ad2web/decoder.py", line 535, in run
self._decoder.open()
File "/opt/alarmdecoder-webapp/ad2web/decoder.py", line 293, in open
self.bind_events()
File "/opt/alarmdecoder-webapp/ad2web/decoder.py", line 324, in bind_events
self.device.on_ready_changed += build_message_handler('ready')
AttributeError: 'AlarmDecoder' object has no attribute 'on_ready_changed'
2018-09-04 19:00:18,508 INFO: Attempting to reconnect to the AlarmDecoder [in /opt/alarmdecoder-webapp/ad2web/decoder.py:533
Does anyone know how to fix this? The reason that I did the clean install was because I was getting the same error before. Any help would be greatly appreciated
miragejb
Re: AlarmDecoder object has no attribute 'on_ready_changed'
Postby kevin » Thu Sep 06, 2018 4:59 pm
make sure your library is up to date
cd /opt/alarmdecoder
git pull origin master
sudo python setup.py install
