Home Assistant RPI3 AD2PI
Postby danmarotta5 » Sun Oct 14, 2018 9:37 am
i've installed alarmdecoder (2.2a.8.8) with home assistant (0.80) ... all is working well however i have one window that after ~1 day with show
incorrect values on home assistant badge (a closer inspection show open/close values oscillating) with HA showing the window closed... the window is open however ... if i reset the window (close/open) all is well again for HA reporting. other zones don't seem to have an issue and a parallel dsc interface (envisalink) shows correct values
the alarm panel display for alarmdecoder shows (not ready so it sees an open relay)... the dsc panel is not ready as well
is there a way to check alarmdecoders internal open/close status for this zone either with swagger or a simple program?
thanks in advance, dan
danmarotta5
