Not seeing how sensors are detected
Postby ehinke27 » Sat Aug 30, 2014 1:38 pm
I have installed ad2usb into my vista 10 and ran through a couple of the doors and sensors to see what events were generated. I used the virtual software that was provided and it did not update the status of the door sensors in the program. I do not see how it can differentiate what door or sensor was opened. I compared the logs and the events are the same. Below are a sample of logs where I opened a garage door, tried setting the alarm with the door open and the clearing alarm. Then repeating the same thing upstairs on a window and moving infront of a motion sensors. The log lines look to be the same.
8/30/2014 1:26:18 PM [1000000110000000----],004,[f70000008004001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:26:29 PM [1000000110000000----],004,[f70000008004001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:26:30 PM !Sending..done
8/30/2014 1:26:31 PM !Sending..done
8/30/2014 1:26:35 PM [0011030110000000----],004,[f70000008004038c28000000000000],"ARMED ***STAY***You may exit now"
8/30/2014 1:26:35 PM !MS> sending alert: AD2USBGUI Alert: System Armed
8/30/2014 1:26:35 PM !MS> Error sending alert: The SMTP host was not found.
8/30/2014 1:26:46 PM [0011000110000000----],004,[f70000008004008c28000000000000],"ARMED ***STAY***You may exit now"
8/30/2014 1:26:57 PM [0011000110000000----],004,[f70000008004008c28000000000000],"ARMED ***STAY***You may exit now"
8/30/2014 1:27:03 PM !Sending..done
8/30/2014 1:27:07 PM [1001010110000000----],004,[f70000008004011c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:27:07 PM !MS> sending alert: AD2USBGUI Alert: System Disarmed
8/30/2014 1:27:07 PM !MS> Error sending alert: The SMTP host was not found.
8/30/2014 1:27:17 PM [1001000110000000----],004,[f70000008004001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:27:28 PM [1001000110000000----],004,[f70000008004001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:27:39 PM [1001000110000000----],004,[f70000008004001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:27:50 PM [1001000110000000----],004,[f70000008004001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:28:03 PM [0001030110000000----],004,[f70000008004030c28000000000000]," DISARMED CHIME Press * Key     " - open Garage door
8/30/2014 1:28:08 PM !Sending..done - set alarm
8/30/2014 1:28:09 PM !Sending..done
8/30/2014 1:28:14 PM [0001010110000000----],001,[f70000008001010028000000000000],"FAULT 01 ZONE 01                "
8/30/2014 1:28:17 PM !Sending..done - turn off alarm
8/30/2014 1:28:19 PM !Sending..done
8/30/2014 1:28:19 PM [1001000110000000----],001,[f70000008001001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:28:20 PM !Sending..done
8/30/2014 1:28:23 PM [1001010110000000----],001,[f70000008001011c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:28:33 PM [1001000110000000----],001,[f70000008001001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:28:44 PM [1001000110000000----],001,[f70000008001001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:28:54 PM [1001000110000000----],001,[f70000008001001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:29:06 PM [0001030110000000----],001,[f70000008001030c28000000000000]," DISARMED CHIME Press * Key     " - open garage door
8/30/2014 1:29:10 PM !Sending..done - set alarm
8/30/2014 1:29:11 PM !Sending..done
8/30/2014 1:29:16 PM [0001010110000000----],002,[f70000008002010028000000000000],"FAULT 02 ZONE 02                "
8/30/2014 1:29:18 PM !Sending..done -- Turn off alarm
8/30/2014 1:29:19 PM !Sending..done
8/30/2014 1:29:19 PM [0001000110000000----],002,[f70000008002000028000000000000],"FAULT 02 ZONE 02                "
8/30/2014 1:29:20 PM !Sending..done
8/30/2014 1:29:22 PM [0001010110000000----],002,[f70000008002010c28000000000000]," DISARMED CHIME Press * Key     " - probably motion sensor
8/30/2014 1:29:34 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:29:44 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:29:55 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:30:07 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:30:19 PM [0001000110000000----],002,[f70000008002000c28000000000000]," DISARMED CHIME Press * Key     " - probably motion sensor
8/30/2014 1:30:21 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:30:24 PM [1000000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:30:35 PM [1000000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:30:40 PM [1000000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:30:44 PM [0000000110000000----],002,[f70000008002000c28000000000000]," DISARMED CHIME Press * Key     " - probably motion sensor
8/30/2014 1:30:49 PM [0000000110000000----],002,[f70000008002000c28000000000000]," DISARMED CHIME Press * Key     "
8/30/2014 1:30:51 PM [1000000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:30:57 PM [1000000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:31:00 PM !Sending..done
8/30/2014 1:31:01 PM !Sending..done
8/30/2014 1:31:04 PM [0101050110000000----],002,[f70000008002050c2c000000000000],"ARMED ***AWAY***You may exit now"
8/30/2014 1:31:04 PM !MS> sending alert: AD2USBGUI Alert: System Armed
8/30/2014 1:31:04 PM !MS> Error sending alert: The SMTP host was not found.
8/30/2014 1:31:05 PM !Sending..done
8/30/2014 1:31:06 PM !Sending..done
8/30/2014 1:31:11 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:31:11 PM !MS> sending alert: AD2USBGUI Alert: System Disarmed
8/30/2014 1:31:11 PM !MS> Error sending alert: The SMTP host was not found.
8/30/2014 1:31:20 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:31:29 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:31:32 PM !Sending..done
8/30/2014 1:31:34 PM !Sending..done
8/30/2014 1:31:35 PM !Sending..done
8/30/2014 1:31:35 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:31:40 PM !Sending..done
8/30/2014 1:31:45 PM !Sending..done
8/30/2014 1:31:45 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:31:46 PM !Sending..done
8/30/2014 1:31:53 PM [0101000110000000----],002,[f70000008002000c2c000000000000],"ARMED ***AWAY***You may exit now"
8/30/2014 1:31:53 PM !MS> sending alert: AD2USBGUI Alert: System Armed
8/30/2014 1:31:53 PM !MS> Error sending alert: The SMTP host was not found.
8/30/2014 1:31:58 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:31:58 PM !MS> sending alert: AD2USBGUI Alert: System Disarmed
8/30/2014 1:31:58 PM !MS> Error sending alert: The SMTP host was not found.
8/30/2014 1:32:06 PM [0001000110000000----],002,[f70000008002000c28000000000000]," DISARMED CHIME Press * Key     "
8/30/2014 1:32:10 PM !Sending..done
8/30/2014 1:32:12 PM !Sending..done
8/30/2014 1:32:21 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:32:27 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:32:38 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:32:42 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:32:53 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:33:01 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:33:08 PM [0001000110000000----],002,[f70000008002000c28000000000000]," DISARMED CHIME Press * Key     "
8/30/2014 1:33:11 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:33:18 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:33:25 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:33:38 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:33:44 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:33:59 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:34:13 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:34:25 PM [0101000110000000----],002,[f70000008002000c2c000000000000],"ARMED ***AWAY***You may exit now"
8/30/2014 1:34:25 PM !MS> sending alert: AD2USBGUI Alert: System Armed
8/30/2014 1:34:25 PM !MS> Error sending alert: The SMTP host was not found.
8/30/2014 1:34:29 PM [0101000110000000----],002,[f70000008002000c2c000000000000],"ARMED ***AWAY***You may exit now"
8/30/2014 1:34:32 PM [1001010110000000----],002,[f70000008002011c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:34:32 PM !MS> sending alert: AD2USBGUI Alert: System Disarmed
8/30/2014 1:34:32 PM !MS> Error sending alert: The SMTP host was not found.
8/30/2014 1:34:40 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:34:47 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:34:54 PM [1001000110000000----],002,[f70000008002001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:35:15 PM [1001000110000000----],006,[f70000008006001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:35:31 PM [1001000110000000----],006,[f70000008006001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:35:41 PM [1001000110000000----],006,[f70000008006001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:35:51 PM [1001000110000000----],006,[f70000008006001c28000000000000]," DISARMED CHIME   Ready to Arm  "
8/30/2014 1:36:02 PM [1000000110000000----],006,[f70000008006001c28000000000000]," DISARMED CHIME   Ready to Arm  "
ehinke27
Re: Not seeing how sensors are detected
Postby mathewss » Sat Aug 30, 2014 3:22 pm
This message is a bit different than I have seen. Press * when you see this on your keypad I suspect it will then send the zone info. The zonetracker module would normally look for "Press * for faults" and then automatically send the "*" to the panel. If that does list the zone info let me know and I will recompile the zone tracker module and send it to you so you can test it.
Postby ehinke27 » Sat Aug 30, 2014 3:47 pm
So when I press* just go to panel and press it or do it from the virtual keypad? Also is there a way to pull the panel configuration via ad2usb (I.e zones, partitions, etc.)
ehinke27
Postby mathewss » Sat Aug 30, 2014 8:53 pm
Real keypad or virtual your choice. I want to see the logs too please as you do this.
ehinke27 wrote:So when I press* just go to panel and press it or do it from the virtual keypad? Also is there a way to pull the panel configuration via ad2usb (I.e zones, partitions, etc.)
The downloader plugin would work but as I recall its only fully tested with 15/20P panels at this time.
Postby ehinke27 » Sat Aug 30, 2014 10:30 pm
pressing * on the panel took care of it. thanks
ehinke27
