Latest Raspbian 9 stretch image is here!
Postby mathewss » Tue Nov 06, 2018 4:59 pm
The latest Raspbian 9 stretch image with all of the AlarmDecoder components pre installed is now available for download here.
https://www.alarmdecoder.com/wiki/index.php/Raspberry_Pi
This image was created using PiBakery and the instructions with the recipe are here https://github.com/nutechsoftware/alarmdecoder-webapp/tree/master/contrib/PiBakery/
You can use PiBakery to enable and configure the WiFi or network settings of this image as a base or you can modify the recipe to create your own custom home automation appliance using a new Raspbian 9 image. You can also opt to modify the settings manually as it would be normally done on Raspbian 9 stretch.
