Build Ser2Sock fails
Postby digger » Mon Nov 26, 2018 7:58 pm
Hi, I have tried to build Ser2Sock on three different servers.
I was using https://github.com/nutechsoftware/ser2sock#installation-debianubuntu for the installation.
On both Ubuntu 14 and 16 LTS it fails with:
dh_installchangelogs
   dh_installinit
   dh_perl
   dh_usrlocal
dh_usrlocal: debian/ser2sock/usr/local/bin/ser2sock is not a directory
rmdir: failed to remove 'debian/ser2sock/usr/local/bin': Directory not empty
dh_usrlocal: rmdir debian/ser2sock/usr/local/bin returned exit code 1
debian/rules:13: recipe for target 'binary' failed
make: *** [binary] Error 1
dpkg-buildpackage: error: fakeroot debian/rules binary gave error exit status 2
debuild: fatal error at line 1376:
dpkg-buildpackage -rfakeroot -D -us -uc -i -b failed
I then tried building on Raspbian 9, it got much further but still failed.
make[1]: Entering directory '/home/pi/ser2sock'
make[1]: Leaving directory '/home/pi/ser2sock'
   create-stamp debian/debhelper-build-stamp
dh binary  --with autotools-dev
dh: Compatibility levels before 9 are deprecated (level 8 in use)
   dh_testroot
   dh_prep
   dh_auto_install
dh_auto_install: Compatibility levels before 9 are deprecated (level 8 in use)
   make -j1 install DESTDIR=/home/pi/ser2sock/debian/ser2sock AM_UPDATE_INFO_DIR=no
make[2]: Entering directory '/home/pi/ser2sock'
make[2]: Nothing to be done for 'install-exec-am'.
 /bin/mkdir -p '/home/pi/ser2sock/debian/ser2sock.'
  /usr/bin/install -c ser2sock '/home/pi/ser2sock/debian/ser2sock.'
make[2]: Leaving directory '/home/pi/ser2sock'
   dh_install
dh_install: Compatibility levels before 9 are deprecated (level 8 in use)
   dh_installdocs
dh_installdocs: Compatibility levels before 9 are deprecated (level 8 in use)
dh_installchangelogs: Compatibility levels before 9 are deprecated (level 8 in use)
   dh_installinit
dh_installinit: Compatibility levels before 9 are deprecated (level 8 in use)
   dh_perl
   dh_usrlocal
debuild: fatal error at line 1116:
dpkg-buildpackage -rfakeroot -us -uc -i -b failed
All three system have:
sudo apt-get install build-essential autotools-dev devscripts libssl-dev
[sudo] password for digger:
Reading package lists... Done
Building dependency tree
Reading state information... Done
autotools-dev is already the newest version (20150820.1).
build-essential is already the newest version (12.1ubuntu2).
devscripts is already the newest version (2.16.2ubuntu3).
libssl-dev is already the newest version (1.0.2g-1ubuntu4.13).
0 upgraded, 0 newly installed, 0 to remove and 73 not upgraded.
digger
Re: Build Ser2Sock fails
Postby RiseUp » Thu Mar 12, 2020 12:15 pm
digger wrote:I then tried building on Raspbian 9, it got much further but still failed.
Were you able to figure out the problem? I'm on Raspbian 10, and I'm seeing errors that are quite similar to yours.
RiseUp
Users browsing this forum: No registered users and 40 guests
