Webapp not working after latest updates
Postby andersondg » Mon May 27, 2019 5:51 am
I logged into the web app on my my AD2PI a few days ago and recieved the "Updates Available" message. I applied the latest library and webapp updates, restarted, and am now getting "Services might still be starting - please wait and try again. If this continues, please let us know on GitHub. You can also email us at Support." and "502 Bad Gateway". I am able to telnet and SSH to the AD2PI, but my technical troubleshooting skills are somewhat limited beyond that.
Thank you in advance for your help, and Happy Memorial Day!
andersondg
Re: Webapp not working after latest updates
Postby andersondg » Mon May 27, 2019 9:06 pm
The latest webapp update causes an issue with the webapp which results in a "502 Bad Gateway" message in the browser. I updated what had been a stable version, and then attempted to troubleshoot to no avail. I downloaded the current image (alarm decoder-raspbian-2018-05-29.img) and started over. After going through the initial config I updated the webapp again through alarmdecoder.local/update/ with the same result after restart (IE: 502 Bad Gateway). Unfortunately my ability to troubleshoot further is limited.
andersondg
Postby delphimon » Wed May 29, 2019 9:05 am
I have the same exact same symptoms and problem. Unfortunately, I didn't do an export of settings beforehand (since updates through the UI have always worked for me in the past), so I don't want to blow everything away and reinstall again, set up devices, SmartThings integration, new devices there again, etc. Any suggestions?
delphimon
Postby delphimon » Wed May 29, 2019 5:26 pm
OK, to answer my own question, I had to update the version of Flask using pip, and then I ran into another issue with problem loading ext.cache. This turned out to be a problem with the flask_cache package. I ended up taking the path of least resistance and just manually changed the jinja2ext.py file at line 33 to import from flast_cache rather than flask.ext.cache. I'm sure there is a more elegant solution, but I really didn't want to deal with any more dependencies, and this worked for me.
delphimon
Postby clif » Mon Jun 17, 2019 10:41 am
I just updated today and got the same 502 Bad Gateway error. I wasn't expecting to have to reload my image. :(
I found the sqlite3 DB with the logins, etc. Unless someone has an easy fix to keep things moving forward, I plan go grab the DB and config files and try to get a fresh image back to the way I previously had it. I hope this is not the normal upgrade path.
clif
Postby clif » Tue Jun 18, 2019 5:03 am
Following up. I got back up and running by saving most of my configuration and then doing the PiBakery image.
I saved the Sqlite3 DB on the old image before re-install.
scp pi@alarmdecoder.mynetwork:opt/alarmdecoder-webapp/instance/db.sqlite .
After I reloaded with the latest PiBakery image, I restored the DB.
scp db.sqlite pi@alarmdecoder.mynetwork:.
ssh pi@alarmdecoder.mynetwork
$  cd opt/alarmdecoder-webapp/instance
$  mv db.sqlite db.sqlite_orig
$  mv ~/db.sqlite .
$ sync
$ reboot
That saves your config. logins, etc.
clif
Postby mathewss » Tue Jun 18, 2019 5:32 pm
Thanks Clif. That is a perfect explanation of what I have been doign to help fix peoples systems the past few weeks :)
You will need to download a new image from our site you must have had an older Raspian 8 image and they can not be updated and are not supported by Debian group any longer.
If you need to recover your settings and did not make a backup using the web interfaces prior to updates and now have a 502 error they can be extracted from the system using putty scp and copy the file in /opt/alarmdecoder-webapp/instances/db.sqlite to your local system and after you flash a new disk and power it up you can put this file back and then just reboot the pi and your settings should be restored.
If you have a backup just restore the image power it up and run through the setup with dummy data. Go into setings advanced and re import your settings. Reboot.
At some point I will likely find a way to add an upload at the start of the setup wizard since it is a pointless step when one is rebuilding.
https://www.alarmdecoder.com/wiki/index ... spberry_Pi
Postby jasonsf » Sat Jul 13, 2019 2:26 pm
I also just updated my pi to the PiBakery image. Restored my db.sqlite and am up and running. Question: the logs page gets an error and it looks like the call to alarmdecoder.local/log/retrieve_events_paging_data? is failing with flask errors.
Is there anything I should do with the pibakery image once it is running? Update apt modules? pip modules, etc?
Follow up: The web app notified me of updates so I installed them. Now I'm back where I was before reimaging. The Keypad of the web app shows "Please Wait Loading" and stays that way.
Additional information: App errors keep repeating this (192.168.11.253=alarmdecoder, 192.168.11.251=smartthings hub)
2019-07-16 07:36:27,379 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 07:36:27,380 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 07:41:18,519 INFO: Checking for version updates - last check at: 07-16-2019 07:31:15 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:616]
2019-07-16 07:41:27,417 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 07:41:27,419 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 07:46:27,053 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 07:46:27,055 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 07:51:21,392 INFO: Checking for version updates - last check at: 07-16-2019 07:41:18 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:616]
2019-07-16 07:51:29,176 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 07:51:29,178 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 07:56:27,127 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 07:56:27,132 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 08:01:25,425 INFO: Checking for version updates - last check at: 07-16-2019 07:51:21 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:616]
2019-07-16 08:01:27,006 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 08:01:27,008 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 08:06:26,811 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 08:06:26,813 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 08:11:27,175 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 08:11:27,176 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 08:11:28,046 INFO: Checking for version updates - last check at: 07-16-2019 08:01:25 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:616]
2019-07-16 08:16:27,826 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 08:16:27,828 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 08:21:26,929 INFO: SUBSCRIBE host:192.168.11.253:5000 callback: <http://192.168.11.251:39500/notify> timeout: Second-28800 [in /opt/alarmdecoder-webapp/ad2web/api/views.py:243]
2019-07-16 08:21:26,931 INFO: add_subscriber: 3bf03370-a739-11e9-b80a-b827ebf642c7 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:203]
2019-07-16 08:21:31,115 INFO: Checking for version updates - last check at: 07-16-2019 08:11:28 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:616]
Thanks-
Jason
jasonsf
Postby jasonsf » Tue Jul 16, 2019 7:58 am
At this point, it looks like the only problem I'm having is the Smartthings communication. This started with the latest webapp update, I believe.
From pi to smartthings hub:
pi@AlarmDecoder:~ $ sudo nmap -p 5000 192.168.11.251
Starting Nmap 7.40 ( https://nmap.org ) at 2019-07-16 08:47 PDT
Nmap scan report for 192.168.11.251
Host is up (0.011s latency).
PORT     STATE  SERVICE
5000/tcp closed upnp
MAC Address: D0:52:A8:35:90:B9 (Physical Graph)
Nmap done: 1 IP address (1 host up) scanned in 0.98 seconds
<e:property><panelstate><panel_perimeter_only>False</panel_perimeter_only><panel_chime>False</panel_chime><panel_alarming>False</panel_alarming><panel_battery_trouble>False</panel_battery_trouble><panel_entry_delay_off>False</panel_entry_delay_off><panel_ready>True</panel_ready><panel_fire_detected>False</panel_fire_detected><panel_powered>True</panel_powered><panel_exit>False</panel_exit><panel_panicked>False</panel_panicked><panel_armed_stay>False</panel_armed_stay><panel_type>ADEMCO</panel_type><panel_bypassed>False</panel_bypassed><panel_armed>False</panel_armed><panel_relay_status /><panel_zones_faulted /><last_message_received><!-- --><![CDATA[[10000001000000003A--],008,[f70200051008001c08020000000000],"****DISARMED****  Ready to Arm  "]]><!-- --></last_message_received></panelstate></e:property>
</e:propertyset> [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:462]
2019-07-16 08:55:33,978 INFO: Event UPNPPush Notification Failed: [Errno 113] No route to host line: 464 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:467]
2019-07-16 08:55:33,989 INFO: Event: 0451449:0:0:0:0:0:0 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:422]
2019-07-16 08:55:34,081 ERROR: Error sending notification for UPNPPush: line: 138 UPNPPushNotification Failed: [Errno 113] No route to host line: 464 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:459]
jasonsf
Postby Gordon » Wed Jul 31, 2019 12:04 pm
I’m sure glad someone raised this issue here… I am another one who was confounded when trying to update.
I had not used my system in at least four months due to a move, and not done updates before that for a time since it was working fine. At the new house I got it up and running in short order yesterday. But then I tired to do the update and bricked the app with little clue why. So I restored my RasPi image and rebooted and it worked again, but only until I tried to update again.
Then I found this forum thread and figured out my system was too old to update via the web-app.
Its a bit of a project for me because I run the RasPi on WiFi and access it remotely, so I had to disconnect the wiring at the alarm panel and set up a workstation with keyboard and monitor and the RasPi. I started to set up PiBakery on my Win PC but with my very slow DSL I was looking at hours to download or maybe hours to compile, so I got the image file and logged on via shell to set up the WiFi manually, and restored the sql database as described above. So, all-in-all it was about eight hours to figure out the problem and get it updated but it seems OK now.
I don’t know if this is an issue or not but the App log shows (in part):
NoDeviceError: ('Error opening device at localhost:10000', error(111, 'Connection refused'))
2019-07-31 12:17:21,376 ERROR: Device not found: Error opening device at localhost:10000 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:545]
2019-07-31 12:17:26,385 INFO: Attempting to reconnect to the AlarmDecoder [in /opt/alarmdecoder-webapp/ad2web/decoder.py:541]
2019-07-31 12:17:26,633 WARNING: Open failed: Error opening device at localhost:10000 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:305]
File "/opt/alarmdecoder-webapp/ad2web/decoder.py", line 302, in open
self.device.open(baudrate=self._device_baudrate, no_reader_thread=no_reader_thread)
File "/opt/alarmdecoder/alarmdecoder/decoder.py", line 277, in open
File "/opt/alarmdecoder/alarmdecoder/devices/socket_device.py", line 208, in open
raise NoDeviceError('Error opening device at {0}:{1}'.format(self._host, self._port), err)
2019-07-31 12:17:26,663 ERROR: Device not found: Error opening device at localhost:10000 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:545]
2019-07-31 12:38:22,991 INFO: AlarmDecoder Webapp booting up - v0.8.4-20-g5c16ef5 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:230]
Gordon
