I have been seeing this issue for several updates but now that I have ruled out the home automation system, I'm posting against the following release:
- Code: Select all
AlarmDecoder library commit: 514fe67
AlarmDecoder webapp commit: b0045d8
Address 18
Configbits 0XFF05
Address Mask 0XFFFFFFFFL
Zone Exander Emulation False False False False False
Relay Emulation True True True True
LRR Emulation False
Deduplicate False
Panel Type ADEMCO
Firmware version V2.2a.8.8
Serial Number FFFFFFFF
Device Flags TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;L2;KE;M2;CB;DS;ER;CR
I cut out the event log from the AD2PI WebApp to show the problems that I have detected. This one shows a wireless door sensor faulting but not clearing but the keypad text clearly shows that the sensor cleared. My Vista 20P has a dedicated RF transceiver module on the bus along with the AD2PI and (2) 6160 keypads (no RF on them). Here is the log from today:
- Code: Select all
2019-7-25 7:28:26 PM AUI 120600000000636c02456cf5ec0101010000
2019-7-25 7:28:26 PM AUI 1606000000006463024543f531fb456cf5ec03020106
2019-7-25 7:28:26 PM READY Ready status has changed to False
2019-7-25 7:28:26 PM RFX 0957061:0:0:1:0:0:0
2019-7-25 7:28:26 PM ZONE FAULT Zone LAUNDRY ENTRY DOOR (17) has been faulted.
2019-7-25 7:29:05 PM AUI 120600000000656c02456cf5ec0101010000
2019-7-25 7:29:05 PM AUI 1606000000006663024543f531fb456cf5ec03010101
2019-7-25 7:29:05 PM READY Ready status has changed to True
2019-7-25 7:29:06 PM ZONE RESTORE Zone LAUNDRY ENTRY DOOR (17) has been restored.
2019-7-25 7:29:43 PM RFX 0850041:0:0:0:1:0:0
2019-7-25 7:29:45 PM AUI 120600000000676c02456cf5ec0101010000
2019-7-25 7:29:45 PM AUI 1606000000006063024543f531fb456cf5ec03020106
2019-7-25 7:29:45 PM READY Ready status has changed to False
2019-7-25 7:29:45 PM ZONE FAULT Zone KITCHEN MOTION (20) has been faulted.
2019-7-25 7:29:47 PM RFX 0850041:0:0:0:0:0:0
2019-7-25 7:29:48 PM AUI 120600000000616c02456cf5ec0101010000
2019-7-25 7:29:48 PM AUI 1606000000006263024543f531fb456cf5ec03010101
2019-7-25 7:29:48 PM READY Ready status has changed to True
2019-7-25 7:29:48 PM ZONE RESTORE Zone KITCHEN MOTION (20) has been restored.
ZN17 Laundry Entry Door (RFX:0957061) faulted but did not restore. On the WebApp, everything looks OK because you get this:
- Code: Select all
On the home automation system, it is easy to spot the missing restore events, but now I suspect that I may be missing fault events without having an indication.
Please let me know if I can debug this further. I have the ability to test down to the hardware level if it comes to that.
