AD2PI fails when Encrypt ser2sock is selected
Postby smartin » Thu Jun 04, 2020 7:35 am
I have been using AD2PI on my LAN for a year WITHOUT encryption.
Now I want to start using HTTPS, so I selected "Encrypt ser2sock" in the setup.
This produces the following errors:
Device Testing
Opening device ✘ Failed to open the device: [('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')]
Saving device configuration ✘ There was an error sending the command to the device.
Keypad communication (Send) ✘ There was an error sending the command to the device.
Keypad communication (Receive) ✘ There was an error sending the command to the device.
If I go back and DESELECT "Encrypt ser2sock", the device tests pass.
What should I do to get encryption to work?
Thanks in advance for any suggestions.
Setup is as follows:
Device: AD2PI
Device Location: Local Device
Path: /dev/serial0
Baudrate: 115200
Share AlarmDecoder on your network: checked
SER2SOCK Configuration Path: /etc/ser2sock
Address: localhost
Port: 10000
Encrypt ser2sock?: Tests fail if checked, but pass if unchecked
Versions
Firmware: V2.2a.8.8
AlarmDecoder Webapp and Library are "Up to date" as of today.
smartin
Users browsing this forum: No registered users and 14 guests
