Newer firmware shows msg corruption with old Vista 20SE
Postby latenitetech » Sat Sep 19, 2020 4:57 pm
New user here, just received and am getting familiar with AD2pHAT device. First, an amazing collection of hardware/software, so thanks for all the hard work that went into this product. After a bit of a learning curve, I've got it mostly figured out, but having difficulty getting it running stable and reliable.
As for background, I have it mounted on a headless RPiZero, running the latest AlarmDecoder-provided "Raspbian Buster 10 PiBakery build." I updated the Raspbian image to the latest Buster code via 'apt-get update' and 'apt-get dist-upgrade', etc. I configured the unit using the webapp interface from a Windows PC and updated the webapp sw to most current via the webapp's interface. I have installed and am using the AlarmDecoder Keypad App V2.0.10 on the same Windows PC. My alarm system is a 20-yr old (originally installed in July 2000) ADT Safewatch Pro 2000, Vista 20SE system board. It is not currently connected to ADT monitoring service, it's just a stand-alone (fairly extensive) local system.
Initially it appeared everything was working correctly, but as I got a bit further into trying to use it, I ran into severe issues with controlling the Alarm system via the AlarmDecoder's keypad interface, either via the webapp or the Keypad App. Specifically, when I go into Program Mode on the alarm panel [installer code + 800], and then *82 for altering the alpha descriptions for zones, the AlarmDecoder seems to get lost. It will display garbage and partial messages on the AlarmDecoder's display, keypad entries are not acted on, and the KeyPad App was even reporting fire trouble messages coming and going (and no, the alarm panel was not alarming). Note that these functions work fine when entered from the "real" ADT keypad. At one point it was so hosed up I had to power-cycle the alarm panel to get any keypad working again.
Initially I was on firmware 2.2a.8.8 (that's what came loaded), but based on another posting here, it was suggested the latest beta release may be better, so I upgraded the firmware to 2.2a.8.9b-306. Bad idea - the message corruption was different, but even worse. So I started shopping around with different firmware versions and finally landed on 2.2a.6, the version labeled "ADEMCO OLD Protocol." That one does seem to work (I am able to properly program the alarm system just like I'm in front of the real keypad), BUT it appears the most current webapp is incompatible with that old firmware. When going through setup via the webapp, it always fails on the "Keypad communication (Receive)" step, saying "Test timed out," and worse, when viewing the live log messages via the Log function of the Keypad App, it is rolling on a repeated sequence of
!CONFIG>ADDRESS=31&CONFIGBITS=ff05&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
!VER:ffffffff,V2.2a.6,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB
repeating every 10 seconds with other expected messages interspersed (e.g "DISARMED CHIME Ready to Arm", !RFX …)
I know the repeating "!> …" is coming from the webapp because if I kill the web app (sudo systemctl stop gunicorn) and then manually restart the ser2sock process, the system behaves normally, but only via the Keypad App.
So I'd like some advice on where to go from here. I'd like to have the webapp working and available, but I also want a stable firmware that will work with my old panel. And I'm fine with sticking with that old firmware unless there is significant functionality I'm missing. Is there an older version of the webapp that will work properly with that firmware? Or perhaps just tell me which python file needs to be tweaked to stop the rolling "!> …" ?
I can certainly provide detailed logs of what's happening with the newer firmware, but suffice it to say it's not pretty, and I don't expect anyone to put any work into fixing it since it's obviously a non-issue to the vast majority of users on newer panels.
Thanks for any help that can be provided!
- Mark
latenitetech
Re: Newer firmware shows msg corruption with old Vista 20SE
Postby mathewss » Sat Sep 19, 2020 7:52 pm
Well meh :) I have SE panels to test with and AFAIK it is stable on 2.2a.8.9.
Please load 2.2a.8.9 beta then using Putty or a telnet client connect to your AD2Pi on ser2sock port 10000 and record some sessions with your alarm.
I need to see these errors.
Once you have some good examples of errors then enable debugging by typing @48<ENTER>
This will dump LOTS Of junk but i need that data to see the errors. Hopefully you will see a bad message and the debug info and with that I can fix it.
Getting 2.2a.6 working with WEBAPP will be painful at best but it is also possible. In any case lets figure out what then I can work on how to get it fixed. Long term sure a 20p is a better panel but I have many many many users with SE panels and it works. Some issues do exist with bad devices causing errors on the bus etc but that shoudl show up on debugging.
Postby latenitetech » Sat Sep 19, 2020 9:48 pm
Sean, thx for the quick reply. I loaded the latest beta firmware (ademcoemu_V2-2a-8-9b-306.hex) and used putty to telnet into the ser2sock server. It's easy to start seeing the issue, just enter the 'installer code'+800 (6321800 in my case) and immediately the response is truncated to "ler Code 20 ". I then entered *82 and it just hangs. Enter 00 and it kicks it into an unusual "Pgm 82" mode, then *99 and exit program mode.
I then turned on debug with @48 and ran the same sequence as above. The only difference is I had to do the *99 twice when in debug mode to get it out of program mode. The putty log file is attached, as well as the log from the KeyPad App which also includes it's own confusion reporting various alarms about fire and StickBit. I didn't have any of those issues when running with the old V2.2a.6 firmware. Hopefully you can see something useful in these logs.
- Mark
latenitetech
Postby latenitetech » Sat Sep 19, 2020 9:55 pm
I don't see the attachments. Perhaps I didn't do it right. I'll just post the log files here as text in case they didn't come through ...
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.09.20 00:25:15 =~=~=~=~=~=~=~=~=~=~=~=
[10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
!sn:ffffffff
!boot....................
!Ademco Keypad Emulator V2.2a.8.9b-306
!Copyright (C) 2008-2015 Nu Tech Software Solutions, Inc.
!Reproduction without permission is prohibited
!By Sean Mathews <coder@f34r.com>
!For support email AlarmDecoder@support.nutech.com
!www.AlarmDecoder.com
!Reading configuration.
!UART init.
VER
!VER:ffffffff,V2.2a.8.9b-306,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;L2;KE;M2;CB;DS;ER;CR
!ERR:0
632180[10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
0
!Sending..done
!Sending..done
!Sending..done
!Sending..done
!Sending..done
!Sending..done
!Sending..done
[00001110111101103A--],0fe,[f700000080fe496e7374616c000000],"ler Code                20      "
*82
!Sending..done
!Sending..done
!Sending..done
00
!Sending..done
!Sending..done
[00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
*99[00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
!Sending..done
!Sending..done
!Sending..done
@48
!>Diag. Flag (0) :>48
!DBG:*ff*[ff][20][20][52][65]<ff><ff>
!DBG:*ff*[ff][61][64][79][20]<ff><ff>
!DBG:*ff*[ff][74][6f][20][41]<ff><ff>
!DBG:*ff*[ff][72][6d][20][20]<ff>
!DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
!DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>6<ff><ff>3<ff><ff>
2!DBG:*00*[00][00][1c][28]<ff><ff>1
!DBG:*fe*[fe][20][44][49][53]<ff><ff>
!DBG:*ff*[ff][41][52][4d][45]<ff><ff>8
!DBG:*ff*[ff][44][20][43][48]<ff><ff>0
!DBG:*ff*[ff][49][4d][45][20]<ff><ff>0
!Sending.!DBG:(78)(0c)(20)(0f).done
!Sending.!DBG:<ff>(1e)(fc)
!DBG:*ff*[ff][72][6d][20][20]<ff>(1e)(cc)(80)(0f).done
!DBG:(fe)<ff>
!Sending.!DBG:(18)(0f)(e0)(0c).done
!Sending.!DBG:<ff>(06)(cf)(e0)(03).done
!Sending.!DBG:<ff>(80)(0f)(e6)(c0).done
!Sending.!DBG:<ff>(00)(0c)(80)(00)(fe).done
!Sending.!DBG:<ff>(00)(0c)(80)(00).done
!DBG:(fe)<ff>
!DBG:*d1*[d1][00][00][28]<ff>
!DBG:*fe*[fe][c2][75][73][79]<ff>
!DBG:*ff*[ff][20][2d][20][53]<ff>
!DBG:*ff*[ff][74][61][6e][64]<ff>
!DBG:*ff*[ff][62][79][20][20]<ff><ff>
!DBG:*00*[00][00][00][40]<ff>
!DBG:*fe*[fe]<ff><ff>
!DBG:*20*[20][00][00][40]<ff>
!DBG:*fe*[fe][49][6e][73][74][61][6c][6c][65][72][20][43][6f][64][65][20][20][20][20][20]
!DBG:[20][20][20][20][20][20][20][20][20][20][20][32][30]<ff><ff><ff><ff><ff><ff><ff>
!DBG:*20*[20][00][0c][40]<ff>
!DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
!DBG:<ff><ff><ff><ff><ff><ff><ff><ff>*<ff><ff>
!DBG:*820*[20][00][0c][40]<ff>
!DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff>2<ff>
!Sending.!DBG:<ff>(98)(0c)(86)(cc)(fe).done
!Sending.!DBG:<ff>(80)(ff)
!DBG:*20*[20][00][0c][40]<ff>(80)(ff)
!DBG:*fe*[fe][71]<ff>(80)(0f)(e6)(c0).done
!Sending.!DBG:<ff>(18)(ff)
!DBG:*80*[80][00][04][40]<ff>(18)(ff)
!DBG:*fe*[fe]<ff>(18)(0f)(e0)(0c).done
!DBG:<ff>
!DBG:*82*[82][00][00][40]<ff>
!DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
!DBG:[20][31][3d][59][65][73][20][20][ff]<ff><ff>
!DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
!DBG:*fe*[fe][50][72][6f][67][72][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d]
!DBG:[4e][6f][20][2c][20][31][3d][59][65][73][20][20][30]<ff><ff>
!DBG:[4e][6f][20][2c][20][31][3d][59][65][73][20][20][ff]<ff><ff>
!DBG:*fe*[fe][34][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
!DBG:*fe*[fe][af][4f][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20]
!DBG:[2c][20][31][3d][59][65][73][20][20][ff]<ff><ff>
!DBG:*fe*[fe][34][cd][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20]
!DBG:[2c][20][31][3d][59][65][73][20][20][30]<ff><ff>
!DBG:*fe*[fe]<ff>0<ff>
!DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>0
!Sending.!DBG:(00)(fc)
!DBG:*82*[82][00][00][40]<ff>(00)(fc)
!DBG:*fe*[fe]<ff>(00)(0c)(80)(00)(fe).done
!DBG:<ff>
!DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
!DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff>(00)(0c)(80)(00)(fe)<ff>.done
!DBG:*82*[82][00][0c][40]<ff>
!DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
!DBG:<ff><ff><ff><ff><ff>^?<ff><ff><ff><ff>9<ff>
!DBG:*82*[82][00][0c][40]<ff>9
!Sending.!DBG:(86)(cc)(86)(c3)(fe).done
!Sending.!DBG:<ff>(86)(fc)
!DBG:*82*[82][00][0c][40]<ff>(86)(fc)
!DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff>(86)(cc)(86)(c3)(fe).done
!DBG:<ff>
!DBG:*fe*[fe][41][6c][70]*[68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
!DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff>9<ff>9<ff><ff><ff>
!DBG:<ff>
!Sending.!DBG:(98)(0c)(86)(cc)(fe).done
!DBG:*fe*[fe]<ff>(86)(cc)(86)(c3)(fe).done
!DBG:*90*[90][00][04][40]<ff>(86)(fc)
!DBG:*fe*[fe][71]<ff>(86)(cc)(86)(c3)(fe).done
!DBG:<ff>
!DBG:*99*[99][00][00][40]<ff>
!DBG:*fe*[fe]<ff>
!DBG:*99*[99][00][00][00]<ff>
!DBG:*fb*[fb][02][20][81][62](00)(24)(00)(dc)<ff><ff><ff>
!DBG:*fb*[fb][02][25][82][5c](00)(21)(03)(dc)<ff><ff>
!sn:ffffffff
!UART init.
latenitetech
Postby latenitetech » Sat Sep 19, 2020 9:57 pm
Also, I didn't capture the config status line in the log above, so here it is:
!CONFIG>MODE=A&CONFIGBITS=ff00&ADDRESS=31&LRR=N&COM=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=Y
Log file from KeyPad App (same time interval as Putty log above):
9/20/2020 12:25:15 AM [10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
9/20/2020 12:25:21 AM !sn:ffffffff
9/20/2020 12:25:25 AM !boot....................
9/20/2020 12:25:25 AM !Ademco Keypad Emulator V2.2a.8.9b-306
9/20/2020 12:25:25 AM !Copyright (C) 2008-2015 Nu Tech Software Solutions, Inc.
9/20/2020 12:25:25 AM !Reproduction without permission is prohibited
9/20/2020 12:25:25 AM !By Sean Mathews <coder@f34r.com>
9/20/2020 12:25:25 AM !For support email AlarmDecoder@support.nutech.com
9/20/2020 12:25:25 AM !www.AlarmDecoder.com
9/20/2020 12:25:25 AM !Reading configuration.
9/20/2020 12:25:25 AM !UART init.
9/20/2020 12:25:25 AM !Ready. Press ! for configuration.
9/20/2020 12:25:29 AM !VER:ffffffff,V2.2a.8.9b-306,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;L2;KE;M2;CB;DS;ER;CR
9/20/2020 12:25:29 AM !ERR:0
9/20/2020 12:25:37 AM [10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
9/20/2020 12:25:39 AM !Sending..done
9/20/2020 12:25:40 AM !Sending..done
9/20/2020 12:25:43 AM [00001110111101103A--],0fe,[f700000080fe496e7374616c000000],"ler Code                20      "
9/20/2020 12:25:43 AM !MS> sending alert: AD2USBGUI Alert: System ALARM
9/20/2020 12:25:43 AM !MS> Error sending alert: The SMTP host was not specified.
9/20/2020 12:25:43 AM !MS> sending alert: AD2USBGUI Alert: System Stickbit Set
9/20/2020 12:25:43 AM !MS> sending alert: AD2USBGUI Alert: System Fire Active
9/20/2020 12:25:46 AM [00001110111101103A--],0fe,[f700000080fe496e7374616c000000],"ler Code                20      "
9/20/2020 12:25:50 AM [00001110111101103A--],0fe,[f700000080fe496e7374616c000000],"ler Code                20      "
9/20/2020 12:25:53 AM [00001110111101103A--],0fe,[f700000080fe496e7374616c000000],"ler Code                20      "
9/20/2020 12:25:56 AM !Sending..done
9/20/2020 12:25:57 AM !Sending..done
9/20/2020 12:26:50 AM !Sending..done
9/20/2020 12:26:52 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:26:52 AM !MS> sending alert: AD2USBGUI Alert: System Restored
9/20/2020 12:26:52 AM !MS> Error sending alert: The SMTP host was not specified.
9/20/2020 12:26:52 AM !MS> sending alert: AD2USBGUI Alert: System Stickbit Cleared
9/20/2020 12:26:56 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:26:59 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:27:03 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:27:03 AM !Sending..done
9/20/2020 12:27:04 AM !Sending..done
9/20/2020 12:27:07 AM [10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
9/20/2020 12:27:07 AM !MS> sending alert: AD2USBGUI Alert: System Fire Restored
9/20/2020 12:27:07 AM !MS> Error sending alert: The SMTP host was not specified.
9/20/2020 12:27:18 AM [10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
9/20/2020 12:28:24 AM !>Diag. Flag (0) :
9/20/2020 12:28:24 AM >48
9/20/2020 12:28:24 AM !DBG:*ff*[ff][20][20][52][65]<ff><ff>
9/20/2020 12:28:24 AM !DBG:*ff*[ff][61][64][79][20]<ff><ff>
9/20/2020 12:28:25 AM !DBG:*ff*[ff][74][6f][20][41]<ff><ff>
9/20/2020 12:28:25 AM !DBG:*ff*[ff][72][6d][20][20]<ff>
9/20/2020 12:28:25 AM [10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
9/20/2020 12:28:29 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:28:34 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:28:34 AM !DBG:*00*[00][00][1c][28]<ff><ff>
9/20/2020 12:28:34 AM !DBG:*fe*[fe][20][44][49][53]<ff><ff>
9/20/2020 12:28:34 AM !DBG:*ff*[ff][41][52][4d][45]<ff><ff>
9/20/2020 12:28:35 AM !DBG:*ff*[ff][44][20][43][48]<ff><ff>
9/20/2020 12:28:35 AM !DBG:*ff*[ff][49][4d][45][20]<ff><ff>
9/20/2020 12:28:35 AM !DBG:*ff*[ff][20][20][52][65]<ff><ff>
9/20/2020 12:28:35 AM !DBG:*ff*[ff][61][64][79][20]<ff><ff>
9/20/2020 12:28:35 AM !DBG:*ff*[ff][74][6f][20][41]<ff>
9/20/2020 12:28:36 AM !Sending.!DBG:(78)(0c)(20)(0f).done
9/20/2020 12:28:36 AM !Sending.!DBG:<ff>(1e)(fc)
9/20/2020 12:28:36 AM !DBG:*ff*[ff][72][6d][20][20]<ff>(1e)(cc)(80)(0f).done
9/20/2020 12:28:36 AM [10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
9/20/2020 12:28:36 AM !DBG:(fe)<ff>
9/20/2020 12:28:36 AM !Sending.!DBG:(18)(0f)(e0)(0c).done
9/20/2020 12:28:36 AM !Sending.!DBG:<ff>(06)(cf)(e0)(03).done
9/20/2020 12:28:36 AM !Sending.!DBG:<ff>(80)(0f)(e6)(c0).done
9/20/2020 12:28:36 AM !Sending.!DBG:<ff>(00)(0c)(80)(00)(fe).done
9/20/2020 12:28:37 AM !Sending.!DBG:<ff>(00)(0c)(80)(00).done
9/20/2020 12:28:37 AM !DBG:(fe)<ff>
9/20/2020 12:28:37 AM !DBG:*d1*[d1][00][00][28]<ff>
9/20/2020 12:28:37 AM !DBG:*fe*[fe][c2][75][73][79]<ff>
9/20/2020 12:28:37 AM !DBG:*ff*[ff][20][2d][20][53]<ff>
9/20/2020 12:28:37 AM !DBG:*ff*[ff][74][61][6e][64]<ff>
9/20/2020 12:28:38 AM !DBG:*ff*[ff][62][79][20][20]<ff><ff>
9/20/2020 12:28:38 AM !DBG:*00*[00][00][00][40]<ff>
9/20/2020 12:28:38 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:28:39 AM !DBG:*20*[20][00][00][40]<ff>
9/20/2020 12:28:39 AM !DBG:*fe*[fe][49][6e][73][74][61][6c][6c][65][72][20][43][6f][64][65][20][20][20][20][20]
9/20/2020 12:28:40 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][32][30]<ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:28:40 AM [00001110111101103A--],0fe,[f700000080fe496e7374616c000000],"ler Code                20      "
9/20/2020 12:28:40 AM !MS> sending alert: AD2USBGUI Alert: System ALARM
9/20/2020 12:28:40 AM !MS> Error sending alert: The SMTP host was not specified.
9/20/2020 12:28:40 AM !MS> sending alert: AD2USBGUI Alert: System Stickbit Set
9/20/2020 12:28:40 AM !MS> sending alert: AD2USBGUI Alert: System Fire Active
9/20/2020 12:28:42 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:28:42 AM !DBG:*20*[20][00][0c][40]<ff>
9/20/2020 12:28:42 AM !DBG:*fe*[fe][49][6e][73][74][61][6c][6c][65][72][20][43][6f][64][65][20][20][20][20][20]
9/20/2020 12:28:42 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:28:42 AM !DBG:*20*[20][00][00][40]<ff>
9/20/2020 12:28:43 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][32][30]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:28:43 AM [00001110111101103A--],0fe,[f700000080fe496e7374616c000000],"ler Code                20      "
9/20/2020 12:28:45 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:28:45 AM !DBG:*20*[20][00][0c][40]<ff>
9/20/2020 12:28:45 AM !DBG:*fe*[fe][49][6e][73][74][61][6c][6c][65][72][20][43][6f][64][65][20][20][20][20][20]
9/20/2020 12:28:45 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:28:46 AM !DBG:*20*[20][00][00][40]<ff>
9/20/2020 12:28:46 AM !DBG:*fe*[fe][49][6e][73][74][61][6c][6c][65][72][20][43][6f][64][65][20][20][20][20][20]
9/20/2020 12:28:46 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][32][30]<ff><ff>
9/20/2020 12:28:46 AM !Sending.!DBG:<ff>(98)(0c)(86)(cc)(fe).done
9/20/2020 12:28:46 AM !Sending.!DBG:<ff>(80)(ff)
9/20/2020 12:28:46 AM !DBG:*20*[20][00][0c][40]<ff>(80)(ff)
9/20/2020 12:28:47 AM !DBG:*fe*[fe][71]<ff>(80)(0f)(e6)(c0).done
9/20/2020 12:28:47 AM !Sending.!DBG:<ff>(18)(ff)
9/20/2020 12:28:47 AM !DBG:*80*[80][00][04][40]<ff>(18)(ff)
9/20/2020 12:28:47 AM !DBG:*fe*[fe]<ff>(18)(0f)(e0)(0c).done
9/20/2020 12:28:47 AM !DBG:<ff>
9/20/2020 12:28:47 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:47 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:47 AM !DBG:[20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:47 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:48 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:48 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:48 AM !DBG:[20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:48 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:49 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:49 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:49 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:49 AM !DBG:[20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:50 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:28:50 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:50 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:50 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:50 AM !DBG:*fe*[fe][50][72][6f][67][72][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d]
9/20/2020 12:28:51 AM !DBG:[4e][6f][20][2c][20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:51 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:51 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:51 AM !DBG:[20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:51 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:28:52 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:28:52 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:52 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:52 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:53 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:53 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:53 AM !DBG:[20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:53 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:28:54 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:28:54 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:54 AM !DBG:*fe*[fe][50][72][6f][67][72][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d]
9/20/2020 12:28:54 AM !DBG:[4e][6f][20][2c][20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:54 AM !DBG:*fe*[fe][34][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:54 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:54 AM !DBG:*fe*[fe][af][4f][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20]
9/20/2020 12:28:55 AM !DBG:[2c][20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:55 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:55 AM !DBG:*fe*[fe][50][72][6f][67][72][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d]
9/20/2020 12:28:55 AM !DBG:[4e][6f][20][2c][20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:55 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:55 AM !DBG:[20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:56 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:56 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:56 AM !DBG:*fe*[fe][34][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:56 AM !DBG:[20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:56 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:28:57 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:57 AM !DBG:*fe*[fe][50][72][6f][67][72][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d]
9/20/2020 12:28:57 AM !DBG:[4e][6f][20][2c][20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:57 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:57 AM !DBG:[20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:57 AM !DBG:*fe*[fe][34][cd][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20]
9/20/2020 12:28:57 AM !DBG:[2c][20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:58 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:58 AM !DBG:*fe*[fe][50][72][6f][67][72][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d]
9/20/2020 12:28:58 AM !DBG:[4e][6f][20][2c][20][31][3d][59][65][73][20][20][ff]<ff><ff>
9/20/2020 12:28:58 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:58 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:58 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:28:59 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:28:59 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:28:59 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:28:59 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:29:00 AM !DBG:*fe*[fe]<ff><ff>
9/20/2020 12:29:00 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:00 AM !DBG:*fe*[fe][af][61][6d][20][41][6c][70][68][61][3f][20][20][20][30][3d][4e][6f][20][2c]
9/20/2020 12:29:00 AM !DBG:[20][31][3d][59][65][73][20][20][30]<ff><ff>
9/20/2020 12:29:01 AM !Sending.!DBG:(00)(fc)
9/20/2020 12:29:01 AM !DBG:*82*[82][00][00][40]<ff>(00)(fc)
9/20/2020 12:29:01 AM !DBG:*fe*[fe]<ff>(00)(0c)(80)(00)(fe).done
9/20/2020 12:29:01 AM !DBG:<ff>
9/20/2020 12:29:01 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:01 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff>(00)(0c)(80)(00)(fe)<ff>.done
9/20/2020 12:29:01 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:02 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:02 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:02 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:03 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:03 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:03 AM !MS> sending alert: AD2USBGUI Alert: System Restored
9/20/2020 12:29:03 AM !MS> Error sending alert: The SMTP host was not specified.
9/20/2020 12:29:03 AM !MS> sending alert: AD2USBGUI Alert: System Stickbit Cleared
9/20/2020 12:29:05 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:05 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:05 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:05 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:05 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:07 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:07 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:08 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:09 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:09 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:09 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:09 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:10 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:10 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:12 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:12 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:12 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:12 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:12 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:13 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:14 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:14 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:16 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:16 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:16 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:16 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:16 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:16 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff>
9/20/2020 12:29:16 AM !Sending.!DBG:(86)(cc)(86)(c3)(fe).done
9/20/2020 12:29:17 AM !Sending.!DBG:<ff>(86)(fc)
9/20/2020 12:29:17 AM !DBG:*82*[82][00][0c][40]<ff>(86)(fc)
9/20/2020 12:29:17 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:17 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff>(86)(cc)(86)(c3)(fe).done
9/20/2020 12:29:17 AM !DBG:<ff>
9/20/2020 12:29:17 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:18 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:18 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:20 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:20 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:20 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:20 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:21 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:21 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:22 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:22 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:24 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:24 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:24 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:24 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:24 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:25 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:25 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:27 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:27 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:27 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:28 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:28 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:28 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:29 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:29 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:31 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:31 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:31 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:31 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:31 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:32 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:32 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:34 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:34 AM !DBG:*82*[82][00][0c][40]<ff>
9/20/2020 12:29:34 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:35 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][20][20]<ff><ff>
9/20/2020 12:29:35 AM !DBG:*82*[82][00][00][40]<ff>
9/20/2020 12:29:35 AM !DBG:*fe*[fe][41][6c][70][68][61][20][50][67][6d][20][20][20][20][20][20][20][20][20][20]
9/20/2020 12:29:36 AM !DBG:[20][20][20][20][20][20][20][20][20][20][20][38][32]<ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:36 AM [00001110100101003A--],0fe,[f700000080fe416c70686120000000],"Pgm                     82      "
9/20/2020 12:29:36 AM !DBG:<ff>
9/20/2020 12:29:36 AM !Sending.!DBG:(98)(0c)(86)(cc)(fe).done
9/20/2020 12:29:36 AM !Sending.!DBG:<ff>(86)(fc)
9/20/2020 12:29:36 AM !DBG:*82*[82][00][0c][40]<ff>(86)(fc)
9/20/2020 12:29:37 AM !DBG:*fe*[fe]<ff>(86)(cc)(86)(c3)(fe).done
9/20/2020 12:29:37 AM !Sending.!DBG:<ff>(86)(fc)
9/20/2020 12:29:37 AM !DBG:*90*[90][00][04][40]<ff>(86)(fc)
9/20/2020 12:29:37 AM !DBG:*fe*[fe][71]<ff>(86)(cc)(86)(c3)(fe).done
9/20/2020 12:29:37 AM !DBG:<ff>
9/20/2020 12:29:37 AM !DBG:*99*[99][00][00][40]<ff>
9/20/2020 12:29:38 AM !DBG:*99*[99][00][00][00]<ff>
9/20/2020 12:29:39 AM !DBG:*fb*[fb][02][20][81][62](00)(24)(00)(dc)<ff><ff><ff>
9/20/2020 12:29:39 AM !DBG:*00*[00][00][1c][28]<ff><ff>
9/20/2020 12:29:39 AM !DBG:*fb*[fb][02][25][82][5c](00)(21)(03)(dc)<ff><ff>
9/20/2020 12:29:39 AM !DBG:*fe*[fe][20][44][49][53]<ff><ff>
9/20/2020 12:29:39 AM !DBG:*ff*[ff][41][52][4d][45]<ff><ff>
9/20/2020 12:29:40 AM !DBG:*ff*[ff][44][20][43][48]<ff><ff>
9/20/2020 12:29:40 AM !DBG:*ff*[ff][49][4d][45][20]<ff><ff>
9/20/2020 12:29:40 AM !DBG:*ff*[ff][20][20][52][65]<ff><ff>
9/20/2020 12:29:40 AM !DBG:*ff*[ff][61][64][79][20]<ff><ff>
9/20/2020 12:29:41 AM !DBG:*ff*[ff][74][6f][20][41]<ff><ff>
9/20/2020 12:29:41 AM !DBG:*ff*[ff][72][6d][20][20]
9/20/2020 12:29:41 AM [10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
9/20/2020 12:29:41 AM !MS> sending alert: AD2USBGUI Alert: System Fire Restored
9/20/2020 12:29:41 AM !MS> Error sending alert: The SMTP host was not specified.
9/20/2020 12:29:45 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:49 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:50 AM !DBG:*00*[00][00][1c][28]<ff><ff>
9/20/2020 12:29:50 AM !DBG:*fe*[fe][20][44][49][53]<ff><ff>
9/20/2020 12:29:50 AM !DBG:*ff*[ff][41][52][4d][45]<ff><ff>
9/20/2020 12:29:50 AM !DBG:*ff*[ff][44][20][43][48]<ff><ff>
9/20/2020 12:29:51 AM !DBG:*ff*[ff][49][4d][45][20]<ff><ff>
9/20/2020 12:29:51 AM !DBG:*ff*[ff][20][20][52][65]<ff><ff>
9/20/2020 12:29:51 AM !DBG:*ff*[ff][61][64][79][20]<ff><ff>
9/20/2020 12:29:51 AM !DBG:*ff*[ff][74][6f][20][41]<ff><ff>
9/20/2020 12:29:51 AM !DBG:*ff*[ff][72][6d][20][20]
9/20/2020 12:29:52 AM [10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
9/20/2020 12:29:55 AM !DBG:<ff><ff><ff><ff><ff><ff><ff><ff><ff><ff><ff>
9/20/2020 12:29:55 AM !sn:ffffffff
9/20/2020 12:29:59 AM !boot....................
9/20/2020 12:29:59 AM !Ademco Keypad Emulator V2.2a.8.9b-306
9/20/2020 12:29:59 AM !Copyright (C) 2008-2015 Nu Tech Software Solutions, Inc.
9/20/2020 12:29:59 AM !Reproduction without permission is prohibited
9/20/2020 12:29:59 AM !By Sean Mathews <coder@f34r.com>
9/20/2020 12:29:59 AM !For support email AlarmDecoder@support.nutech.com
9/20/2020 12:29:59 AM !www.AlarmDecoder.com
9/20/2020 12:29:59 AM !Reading configuration.
9/20/2020 12:29:59 AM !UART init.
9/20/2020 12:29:59 AM !Ready. Press ! for configuration.
9/20/2020 12:30:03 AM [10000001100000003A--],000,[f70000008000001c28000000000000]," DISARMED CHIME   Ready to Arm  "
9/20/2020 12:36:21 AM !RFX:0132602,04
9/20/2020 12:36:21 AM !EX> Item List changed name: 0132602 id: 132602
latenitetech
Postby latenitetech » Sun Sep 20, 2020 6:38 pm
Sean,
One more thing I thought of that might be useful to you, or perhaps it's obvious …
If I stand in front of my ADT keypad, and enter in key presses via the webapp (on my cell phone), I can manipulate the alarm panel properly. That is, the input side of AlarmDecoder via the webapp sending input to the alarm panel is working properly. It's the output side, the messages that get displayed on the virtual keypad, that are corrupt. The messages being displayed on the real ADT keypad are as I would expect.
In my first posting, I stated I once had to power-cycle the system to recover it, but in retrospect had I simply looked at the ADT keypad, I probably could have figured out what state it was in and what input it was expecting to properly exit program mode. It just didn't occur to me as the ADT keypad is not very conveniently located relative to my office where I'm interacting with the AlarmDecoder RPi via my office PC.
Given the above knowledge, I could produce a much more extensive log session if that would be useful, as it appears all (or nearly all) the output messages are being interpreted incorrectly once one enters into program mode. The log I submitted yesterday is only the tip of the iceberg as I didn't go very deep before exiting out. But hopefully it's an obvious problem that once fixed, will correct all the output messages when in program mode.
Looking forward to your analysis and feedback.
- Mark
latenitetech
Postby mathewss » Sun Oct 04, 2020 12:37 pm
Sorry for the lag on this reply been busy working on new product dev and when I do I forgot to look around :)
Thanks for the logs. I was able to I think determine the fix but I am not able to build a firmware to test today. I just started update my build system so it will be a week(ish) before I can send a test firmware to try out.
Postby latenitetech » Sun Oct 11, 2020 7:53 pm
Sean,
Thanks for the update. Looking forward to a new firmware to try.
- Mark
latenitetech
Postby latenitetech » Fri Nov 13, 2020 1:12 pm
Friendly poke ... any chance of getting a firmware update any time soon? Although I'm able to get by on the current firmware, it's a bit of a PITA as I can only do program changes to the panel from the "real" keypad, and worse, when I make such changes I have to first shut down the ADwebapp and my Python bridge program or they start screaming about fire alarm, power loss, etc. as AD is obviously confused by the messages it's seeing coming from the panel while in program mode.
I appreciate the support!
- Mark
latenitetech
Postby mathewss » Fri Nov 13, 2020 1:48 pm
Thanks. Need the help keeping focused. Too many tasks. I will work on this over this weekend and report back here.
