Raspberry Pi version B+
PostPosted: Sat Sep 13, 2014 4:37 am
by Dominic
I'm about to buy a Raspberry Pi and just wanted to make sure that the new B+ version is compatible with your customized image beta with the web app.
Dominic
Re: Raspberry Pi version B+
PostPosted: Sat Sep 13, 2014 10:02 am
by xuniman
I'm using a B+ with a AD2USB and the image works fine.
PostPosted: Sat Sep 13, 2014 1:22 pm
The BETA is the one that works with the B+, the nonbeta does not. Beta images are the only ones updated until deemed stable, then that will take over the stable release going forward. yes, the beta image supports the b+
PostPosted: Sat Sep 13, 2014 1:37 pm
by Dominic
Excellent. I use the AD2USB with a windows PC running the keypad GUI now but I'm planning to switch to a Raspberry Pi running the web app for a much lower power and smaller option. Thanks!
PostPosted: Sat Sep 13, 2014 4:58 pm
The cool part about using the raspberry pi and the webapp is that you can still use the keypad application at the same time using the socket connection options!
