Scan Panel to discover zones not working with Vista-21ip
Postby bwyer » Thu Oct 15, 2020 10:44 am
I just got the AD2PI appliance up and running with my Vista-21IP and the web page is working like a champ. Keypad responds, seeing events logging, etc.
Now, I'd like to finish setting it up, so I went in to query the zone names in the zone setup page. I know the zones are set up correctly as they show up in my 6280 keypad as well as in TotalConnect.
When I click Scan Panel, it pauses for a few seconds, the bar goes to 1% and then the spinner just sits there. Checking the events, there's nothing unique coming from the panel either; certainly not a list of zone names. It's like the panel just ignored the command (assuming it was sent).
I've tried updating to the beta firmware (2.2a.8.9b-306) as well as the dev branch and don't see any different results.
Here is the information from the diagnostics:
AlarmDecoder device settings:
Address   18
Configbits   0XFF05
Address Mask   0XFFFFFFFFL
Zone Exander Emulation   False False False False False
Relay Emulation   False False False False
LRR Emulation   False
Deduplicate   False
Panel Type   ADEMCO
Firmware version   V2.2a.8.9b-306
Serial Number   FFFFFFFF
Device Flags   TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;L2;KE;M2;CB;DS;ER;CR
Here is the block of events just before and during a panel query:
2020-10-15 11:42:31,632 INFO: Event: 0308441:0:0:1:0:0:0 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:42:32,169 INFO: Event: 0e020000000052fefeec01010101 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:42:37,335 INFO: Event: 0425038:0:1:0:0:0:0 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:42:42,159 INFO: Event: 0e020000000053fefeec01010101 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:42:52,288 INFO: Event: 0e020000000054feec0101010000 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:42:52,630 INFO: Event: 0e020000000055fefeec01010101 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:42:52,971 INFO: Event: 16020000000056feec32303130313531333431343934 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:42:53,276 INFO: Event: 0a020000000057fefe30 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:43:02,197 INFO: Event: 0e020000000050fefeec01010101 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:43:20,748 INFO: Event: 0e020000000051fefeec01010101 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:43:22,316 INFO: Event: 0e020000000052feec0101010000 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:43:22,656 INFO: Event: 0e020000000053fefeec01010101 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:43:24,191 INFO: Event: 0246360:0:0:1:0:0:0 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:43:27,493 INFO: Event: 0246360:0:0:0:0:0:0 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
2020-10-15 11:43:32,225 INFO: Event: 0e020000000054fefeec01010101 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:527]
Thank you
bwyer
Re: Scan Panel to discover zones not working with Vista-21ip
Postby haydenhill » Thu Oct 15, 2020 11:02 am
I am having the same issue. Vista21IPLTE.
haydenhill
Postby hudoh » Thu Oct 15, 2020 1:30 pm
I've always had the same issue on my Vista-20P. It has never worked for me and just gets stuck on 1%. But not having the zones listed has never actually been a problem. I use my AD2PI with Smartthings App and realized I really didn't need the zones showing up correctly in the webapp since the zone numbers showed in in Smartthings and I could name them there. It always annoyed me that it didn't work, but I didn't ever find the need for it. If you find a solution, would love to know what it is.
hudoh
Postby kd7mlg » Thu Oct 15, 2020 11:38 pm
I've been having the same issue with an older V20P (R8.1).
As near as I can tell, the routine is getting to a location that doesn't exist in the Panel's EEPROM and not recovering gracefully. It might be #29 or #30 ... If you watch the virtual panel as the routine runs, you'll see the display read 'EE'.
I am primarily tinkering with the AD2 at the moment and just manually set my device names but eventually it would be nice to figure out what the issue is and get it taken care of.
kd7mlg
