Webapp is Missing some events and GUI not connecting
Postby lanzillo » Sat Oct 30, 2021 12:09 pm
I have a Vista 40P running V0.8.5-15-gc75031b. It was working fine after SM provided a patch about 4 months ago. Now, there are 3 symptoms:
1. the WebApp does not report all events ( I see events on the physical keypads but the webapp doesn't report all of them
2. Sometimes it is very slow on reporting events
3. The AlarmdecoderGUI - can not seem to connect to the device - it seems that nothing is listening on port 10000 - see below
a. Not sure if this is correct diagnostic, but "netstat -l -p" does not show 10000 or anything with alarmdecoder
4. Something happened last week that caused DB corruption and it was filling up the logs with error messages….
a. I re-initialized the DB with "python manage.py initdb", imported a prior config and that got me to where I am now.
Thanks for any pointers...
Leo
Output from the GUI:
Starting AlarmDecoderApp build #2.0.10.40818
10/30/2021 2:55:50 PM Trying to DNS resolve: alarmdecoder
10/30/2021 2:55:50 PM Trying to connect to: alarmdecoder:10000
10/30/2021 2:55:51 PM Loding modules. To remove modules use the modules tab under the about menu
10/30/2021 2:55:51 PM Example V1.0 initialized
10/30/2021 2:55:51 PM keypad V1.0 initialized ()
10/30/2021 2:55:51 PM MyStuff V1.0b initialized
10/30/2021 2:55:51 PM ZoneTracker V1.0 initialized
10/30/2021 2:55:58 PM Waiting for communication to AlarmDecoder to open
10/30/2021 2:55:58 PM Communicaiton to AlarmDecoder established
10/30/2021 2:55:58 PM Trying to make sure we are not in config mode sending \r\n A Bunch!
10/30/2021 2:55:58 PM OnSocketReceive failed closing connection
10/30/2021 2:56:00 PM Sending '\r\n' to check if in config mode.
10/30/2021 2:56:01 PM The AlarmDecoder not in config mode. Continuing to initialize.
10/30/2021 2:56:02 PM Sending 'V' command to the AlarmDecoder
10/30/2021 2:56:06 PM Trying to DNS resolve: alarmdecoder
10/30/2021 2:56:06 PM Trying to connect to: alarmdecoder:10000
10/30/2021 2:56:06 PM Timeout waiting for !VER message from the AlarmDecoder
10/30/2021 2:56:07 PM Sending '\r\n' command to the AlarmDecoder
lanzillo
