Backup of Panel Settings
Postby captain118 » Tue Sep 13, 2022 6:35 pm
Is there a script or part of the alarm decoder that will go through all the addresses of the panel and save off the values. It would be nice to know I have a backup of what the panel is set to before I really start screwing with it.
If it matters I have the Vista 20P.
captain118
Re: Backup of Panel Settings
Postby mathewss » Fri Sep 16, 2022 12:55 pm
Yes the downloader will do this when used inside of the AlarmDecoder GUI keypad app.
It has a config file that allows fields to be added/removed. The only bug / feature is that if it gets an invalid reply for a field it takes a long sleep before it continues but it works and you can edit the config to remove or add fields. Many different 20P firmware versions exist with changes in what fields are supported.
This is also available on my store for my Coffee and snack fund.
make_clickable_callback(MAGIC_URL_WWW, ' ', 'www.alarmdecoder.com/downloader.zip', '', ' class="postlink"')
Sean M.
