I recently moved into a new house that had an existing Honeywell Vista 20SE panel. I had an AD2Pi that I brought with me from the old house and attempted to set it up with the Vista 20SE, but I am experiencing instability. Initially since I had no codes for the system I reset the Vista 20SE back to its default settings and started with a fresh install on the AD2Pi and latest firmware.
The initial setup with the AD2Pi worked without issues and the diagnostics passed with the panel as well. I also ensured that address 31 was used, since I understand it is required for the Vista 20SE.
I am able to configure settings on the Vista 20SE from the physical keypad, but since it is not an alphanumeric keypad I am very limited and have no text readout in the menu system. Since I already had an AD2Pi I figured there was no need to purchase an alphanumeric keypad and I was just going to use alarm decoder.
The main issue is if I enter zone programming mode (*56) the virtual keypad freezes and I have no response from the keypad buttons. The display readout is stuck on "installer 20" which is the last command before entering zone programming.
If I then go to the physical keypad and use *99 to exit the zone programming, the virtual keypad then becomes responsive again.
I can telnet into the AD2Pi and send commands without issues, but again as soon as I enter zone programming the virtual keypad freezes.
If I go into another programming option like exit/enter delay the virtual keypad is responsive and there is no issue. The ONLY mode which seems to have an issue is the zone programming.
If I run the diagnostics after the virtual keypad has frozen, I will receive a keypad comm receive error. Below is the output of that diagnostic.
- Code: Select all
!CONFIG>MODE=A&CONFIGBITS=ff05&ADDRESS=31&LRR=N&COM=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
!Reading configuration.
!UART init.
!VER:ffffffff,V2.2a.8.9b-306,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;L2;KE;M2;CB;DS;ER;CR
!>ADDRESS=31&CONFIGBITS=ff05&MASK=ffffffff&EXP=NNNNN&REL=NNNN&LRR=N&DEDUPLICATE=N&MODE=A&COM=N
!UART init.
!Sending..done
!Sending..done
