Ad2serial with Home assistant
Postby jmarty32 » Mon Mar 06, 2023 8:59 am
Hi, I have been using the Ad2serial for many years on Vera with no issues. Recently i switched over to Home Assistant and before doing so I made sure alarm-decoder products were supported. Unfortunately, I can't get home assistant to work. I followed the online instructions but with no luck.
Can someone please guide me in the right direction? I don't want fancy automation just a way to run on and off the panel using my phone or tablet. Thanks
jmarty32
Re: Ad2serial with Home assistant
Postby mathewss » Mon Mar 06, 2023 10:30 am
Probably just baud rate? AD2Serial is 19200.
Only other thought is old firmware. Please confirm your panel type and AD2 firmware version.
Sean M.
Postby jmarty32 » Mon Mar 06, 2023 9:05 pm
Hi Sean,
Thanks for your quick reply. Yes, it might be the firmware since i have one of the first units your produced. I had issues with lightning strikes and you were kind enough to replace it with the serial version which has been rock solid for more than 12 years now.
Is there a tutorial for updating the firmware? Thanks
jmarty32
