failed to install gtk#
Posted: Fri Nov 21, 2014 2:43 pm
I downloaded the virtual keypad AlarmDecoderAp_Windows_2_0_10.exe and when I run the installer it gives the "failed to install gtk#" error with no further explanation, error code, reason. This is on Windows XP.
When I open a Hyperterminal session to COM6 for the ad2usb device, I see messages coming from the Vista panel, at the moment for example "System Lo Bat" is repeating regularly, so the hardware seems to be working OK, but nothing I type in the terminal window has any effect.
So I have two questions, the most important is: how to diagnose the gtk install failure?
The other is: what am I doing wrong with Hyperterminal?
Thanks for your assistance!
