AD2USB and Vista 48
AD2USB and Vista 48
Postby rickboy62 » Tue Dec 23, 2014 5:46 am
Can anyone advise where I can get info on setting up the AD2USB to work with a Vista 48 panel. I previously had it working with my Vista 20 SE but the panel was moved due to renovations and got damaged and I had to upgrade it to a Vista 48. I can't find any info on the forum. Grateful if someone could direct me to what software I need to download. I'm using a Vera 3.
Thanks Rickboy62
rickboy62
Re: AD2USB and Vista 48
Postby mathewss » Tue Dec 23, 2014 10:17 am
Yes the 48 is compatible. You need to change your AD2* address from 31 that your SE panel required to an address that you program into your panel. The install video on our help pages talks about this in detail about using fields ∗191 - 196. Just watch the video and follow its directions and you will be all set.
Postby rickboy62 » Wed Dec 24, 2014 8:34 pm
Thanks for the reply Sean. I called my alarm installer and he said the keypad address no,is 16. Keypad address no 17 or 18 is spare.
Just to confirm then I need to activate another keypad address in y panel and change my ad2usb to match . I can't find the video you mention to change fields *191-196. Can you please send me a link to where it is.
rickboy62
Postby kevin » Thu Dec 25, 2014 6:15 pm
