Webapp: Workaround to support Program Mode
Postby peterd » Fri Jan 09, 2015 12:00 am
There's currently a known bug in the webapp where some panel messages are improperly filtered. The symptom is that the display freezes when you reach a certain point after putting the panel into program mode. This makes programming via the webapp impossible.
I've written the following script to workaround the problem until a fix is integrated into the webapp:
#!/bin/sh
# fix_AD_webapp.sh
# An admitted hack, this script works around an Alarm Decoder
# webapp bug which fails to display certain messages while the
# panel is in programming mode. It does this by proxying I/O
# with the AD2USB webapp and spoofing all message types to a
# value which is known to be accepted.
# To use, change the webapp's listening port from 10000 to 10002.
# Must be run as root, either as a daemon or with the command line
# "sudo fix_AD_webapp.sh"
rm -f /tmp/fifo
mkfifo /tmp/fifo
if [ ! -p /tmp/fifo ]
then
    echo "mkfifo /tmp/fifo FAILED"
    exit 1
fi
nohup netcat -l -k -p 10002 < /tmp/fifo | netcat localhost 10000 \
    | sed -u 's/\[f704[^]][^]]*/\[f704000000008000480200000d0000/' \
    > /tmp/fifo &
I've been running this continuously since September without problems. I hope this helps anyone who wants to program their panel using the webapp...
Peter
Admin - Could you please sticky this until a permanent fix is integrated into the webapp? Thanks!
peterd
Re: Webapp: Workaround to support Program Mode
Postby kevin » Wed Apr 22, 2015 1:55 pm
Unstickying this because there is an official fix in the alarmdecoder library. Anybody affected just needs to do a git pull on the alarmdecoder project (default /opt/alarmdecoder)
