Services might still be starting... Forever
Postby Maxburn » Sat Mar 21, 2015 1:56 pm
Been running fine for a week or two and I asked about SSL for the Webapp but never got around to it. Today I got this message below when trying to get into the Webapp. SSH still works and I told it to reboot, still not working SSH shutdown and pulled the power got the same message after rebooting.
Services might still be starting - please wait and try again. If this continues, please let us know on GitHub. You can also email us at Support.
I searched but didn't see instructions on what log you would need or how to get it?
Maxburn
Re: Services might still be starting... Forever
Postby Maxburn » Sun Mar 22, 2015 4:10 pm
Found this in syslog
alarmdecoder ser2sock[2127]: [‼] Error opening pid file /var/run/ser2sock.pid
and this in nginx log
2015/03/22 21:33:12 [error] 2084#0: *23 connect() failed (111: Connection refused) while connecting to upstream, client: {my ip}, server: , request: "GET /keypad/ HTTP/1.1", upstream: "http://127.0.0.1:5000/keypad/", host: "{my host}"
2015/03/22 21:33:12 [error] 2084#0: *23 connect() failed (111: Connection refused) while connecting to upstream, client: {my ip}, server: , request: "GET /static/favicon.ico HTTP/1.1", upstream: "http://127.0.0.1:5000/static/favicon.ico", host: "{myhost}"
2015/03/22 21:35:58 [error] 2084#0: *26 connect() failed (111: Connection refused) while connecting to upstream, client: {ip}, server: , request: "GET / HTTP/1.1", upstream: "http://127.0.0.1:5000/", host: "{host}"
Don't really know what I'm looking at.
Maxburn
Postby Maxburn » Sun Mar 22, 2015 5:05 pm
Might be hardware? I downloaded the Raspbian image and flashed that to another SD card I had here and got exactly the same results. I even tried putting it back on the external power supply. Already restarted the alarm system and my keypads work fine. Suggestions?
Maxburn
Postby kevin » Sun Mar 22, 2015 6:21 pm
Please make sure ser2sock is functioning correctly by telnetting to port 10000 and see if you can communicate with the alarm successfully
After that, make sure to look at the gunicorn logs - it looks as if the wsgi is not starting properly to accept connections
Postby Maxburn » Mon Mar 23, 2015 2:47 pm
I tried telnet and didn't really get anything, sent C and it closed the session. Sent my code+1 and it closed the connection. I've not really tried to do anything here, not sure what I'm supposed to be getting or even sending.
Next part is weird
Status:          Listing directory /
Status:          Directory listing of "/" successful
Status:          Retrieving directory listing of "/var"...
Status:          Listing directory /var
Status:          Directory listing of "/var" successful
Status:          Retrieving directory listing of "/var/log"...
Status:          Listing directory /var/log
Status:          Directory listing of "/var/log" successful
Status:          Retrieving directory listing of "/var/log/gunicorn"...
Command:    cd "gunicorn"
Error:            Directory /var/log/gunicorn: permission denied
Error:            Failed to retrieve directory listing
Maxburn
Postby kevin » Mon Mar 23, 2015 4:25 pm
Well, we need to make sure your device is working properly and communicating with the alarm panel.
Do you have an AD2Pi or and AD2USB?
SSH into the pi and make sure all ser2sock, nginx, and gunicorn processes are stopped.
Use a serial program such as screen to verify your device works properly
if AD2PI:
sudo screen /dev/ttyAMA0 115200
make sure you are seeing alarm messages and you are able to arm/disarm
if AD2USB:
sudo screen /dev/ttyUSB0 115200 (ttyUSB0 is default, make sure actual device path of your device by checking dmesg and lsusb)
again try to arm/disarm/view messages
Once you have verified it is not a hardware issue, I would suggest removing your database file for the webapp (in /opt/alarmdecoder-webapp) and restarting and going through setup again.
If it's a hardware issue, or still can't be resolved please email ad2usb@support.nutech.com for further troubleshooting - maybe getting us SSH access to see if we can help/check it out.
Postby Maxburn » Mon Mar 23, 2015 4:50 pm
This is an ad2pi.
Thank you for the instructions, I was able to go in and see the messages, arm and disarm etc using sudo screen /dev/ttyAMA0 115200. I guess the hardware is good.
Exactly what files should I be deleting?
Maxburn
Postby kevin » Mon Mar 23, 2015 6:00 pm
you would be deleting /opt/alarmdecoder-webapp/instance/db.sqlite
Also make sure the /etc/ser2sock/ser2sock.conf is defaulted as such:
[ser2sock]
daemonize = 1
device = /dev/ttyAMA0
baudrate = 115200
port = 10000
raw_device_mode = 1
preserve_connections = 1
bind_ip = 0.0.0.0
send_terminal_init = 0
device_open_delay = 5000
encrypted = 0
ca_certificate =
ssl_certificate =
ssl_key =
ssl_crl = /etc/ser2sock/ser2sock.crl
Then you should be able to reboot, and provided your nginx and gunicorn configs haven't been changed - go through the webapp setup and start again.
Postby Maxburn » Tue Mar 24, 2015 2:25 pm
OK, I did those two things and found what happened below but now I have a new problem. Now the web page says starting up for a while and then faults out with this error. I did confirm that it successfully made a new database file, I can see the file.
sqlalchemy.exc.OperationalError
OperationalError: (OperationalError) no such table: settings u'SELECT settings.id AS settings_id, settings.name AS settings_name, settings.int_value AS settings_int_value, settings.string_value AS settings_string_value \nFROM settings \nWHERE settings.name = ?\n LIMIT ? OFFSET ?' ('setup_stage', 1, 0)
I discovered what I did. In the middle of last week sometime I went through the config in the webapp not really understanding the options and turned on SSL so that ser2sock.conf file looked like this for me below, I think I was looking for the webapp SSL. I never really connected the two in my mind because I didn't reboot the device to see the change? Somewhere along the line it must have rebooted and wound up using this config.
What I don't understand is why the replacement system image acted the same way, I didn't get a chance to edit that and the symptoms seemed the same.
[ser2sock]
daemonize = 1
baudrate = 115200
port = 10000
raw_device_mode = 1
bind_ip = 0.0.0.0
encrypted = 1
ca_certificate = /etc/ser2sock/certs/AlarmDecoder CA.pem
ssl_certificate = /etc/ser2sock/certs/AlarmDecoder Server.pem
ssl_key = /etc/ser2sock/certs/AlarmDecoder Server.key
Maxburn
Postby kevin » Tue Mar 24, 2015 2:57 pm
You might need to do this:
cd /opt/alarmdecoder-webapp
sudo python manage.py initdb
This should go through and make sure all the tables are properly created - I forgot to include this step in my previous instructions, sorry. You will still see the error with regards to the settings table, but you should be able to ignore it after this point.
And that SSL is just for ser2sock, not the webapp - I think the error actually stems from the spaces in your filenames
Users browsing this forum: No registered users and 44 guests
