newbie needs help
newbie needs help
Postby csullivan2005 » Thu May 28, 2015 6:18 pm
I installed AD2USB to my Vista20P panel. Alarm decoder displays accurate system status. I'm using homeseer HS3 automation platform and downloaded vista alarm plug in. After I installed homeseer plugin my alarm decoder keypad no longer displayed alarm status and kept saying trying to establish connection to alarm communicator.
Below is my log. SMTP host not found error message comes up
Starting AlarmDecoderApp build #2.0.10.40818
5/28/2015 9:59:52 PM Loding modules. To remove modules use the modules tab under the about menu
5/28/2015 9:59:52 PM Example V1.0 initialized
5/28/2015 9:59:52 PM keypad V1.0 initialized ()
5/28/2015 9:59:52 PM MyStuff V1.0b initialized
5/28/2015 9:59:58 PM Waiting for communication to AlarmDecoder to open
5/28/2015 9:59:58 PM Opening com port: 'COM5'
5/28/2015 9:59:58 PM Communicaiton to AlarmDecoder established
5/28/2015 9:59:58 PM Trying to make sure we are not in config mode sending \r\n A Bunch!
5/28/2015 10:00:00 PM Sending '\r\n' to check if in config mode.
5/28/2015 10:00:01 PM The AlarmDecoder not in config mode. Continuing to initialize.
5/28/2015 10:00:02 PM Sending 'V' command to the AlarmDecoder
5/28/2015 10:00:02 PM !VER:ffffffff,V2.2a.6,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB
5/28/2015 10:00:02 PM Found Version String
5/28/2015 10:00:03 PM Sending 'C' command to the AlarmDecoder
5/28/2015 10:00:03 PM !>
5/28/2015 10:00:03 PM !CONFIG>ADDRESS=18&CONFIGBITS=ff00&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
5/28/2015 10:00:03 PM Found and saving Config String
5/28/2015 10:00:04 PM [0010000110000000----],008,[f70600051008008c28020000000000],"ARMED ***STAY*** "
5/28/2015 10:00:04 PM Sending '\r\n' command to the AlarmDecoder
5/28/2015 10:00:04 PM !MS> sending alert: AD2USBGUI Alert: mystuff initialized: ARMED
5/28/2015 10:00:04 PM !MS> Error sending alert: The SMTP host was not found.
5/28/2015 10:00:14 PM [0010000110000000----],008,[f70600051008008c28020000000000],"ARMED ***STAY*** "
5/28/2015 10:00:24 PM [0010000110000000----],008,[f70600051008008c28020000000000],"ARMED ***STAY*** "
5/28/2015 10:00:34 PM [0010000110000000----],008,[f70600051008008c28020000000000],"ARMED ***STAY*** "
5/28/2015 10:00:44 PM [0010000110000000----],008,[f70600051008008c28020000000000],"ARMED ***STAY*** "
5/28/2015 10:00:53 PM [0010000110000000----],008,[f70600051008008c28020000000000],"ARMED ***STAY*** "
5/28/2015 10:01:03 PM [0010000110000000----],008,[f70600051008008c28020000000000],"ARMED ***STAY*** "
5/28/2015 10:01:13 PM [0010000110000000----],008,[f70600051008008c28020000000000],"ARMED ***
csullivan2005
Re: newbie needs help
Postby kevin » Thu May 28, 2015 8:17 pm
If the ad2usb works correctly with our AlarmDecoder keypad application, I will have to refer you to the homeseer support forum for the plugin. http://board.homeseer.com/forumdisplay. ... c888&f=992 - the creator of the plugin, Mark Sandler has excellent support for his work.
If it's not working in the Keypad application, then we'll start from there.
Users browsing this forum: No registered users and 43 guests
