AD2PI - Do I have to solder it to my RPI?
Postby Derekcomptech » Tue Jun 02, 2015 7:12 am
I am very interested in buying this AD2PI for my soon to be had vista20 system. I have 2 questions.
First, do I have to solder the AD2PI to the RPI or is it similar to a hooking up an IDE ribbon cable on an old pc?
I am not good at soldering though believe me I've tried (JTAG's and modding xbox's).
Second, The vista20p is replacing and an old caddix alarm system. I do not want to purchase a keypad for the vista if I do not have to. From the researching I have done I think I would have to program with a real keypad to put the AD2PI on specific address. What if I want to solely use the AD2PI as my keypad for everything? Is it possible without changing addresses with a real keypad?
In short all i want to purchase is the AD2PI and the vista20p I do not want to purchase a Keypad too unless I have to.
ThX in advance
Derekcomptech
Re: AD2PI - Do I have to solder it to my RPI?
Postby kevin » Tue Jun 02, 2015 5:22 pm
Derekcomptech wrote:Hello,
ThX in advance
No soldering necessary. The header on the AD2Pi board fits directly on the GPIO header - just recommend putting a rubber foot on top of the HDMI connector to prevent AD2Pi board from touching it at the terminal block side.
You can use the AD2Pi as a main alpha keypad on your vista20 by setting the AD2Pi to address 16 - no panel configuration required for address 16 usage. Just go through the AD2Pi configuration to change its address before you can use it on your panel by sending a '!' character to the device and following the prompts.
Postby Derekcomptech » Wed Jun 03, 2015 10:43 am
Thank you for your reply I've went ahead and ordered everything I need.
I need to be able to monitor it remotely and also arm and disarm from my phone remotely. A little information on making this possible will be more then awesome.
Again thank you very much. I do not like the idea of the eyesonevl adapter it has to go through their website. As far as I know this is the only solution for alarm system automation.
Derekcomptech
Postby kevin » Wed Jun 03, 2015 10:47 am
We have a WebApp you can setup to run on your pi and forward a port on your router to access from outside your network
http://www.alarmdecoder.com/wiki/index. ... der_WebApp
https://github.com/nutechsoftware/alarmdecoder-webapp
We have a pre-configured image available here: http://www.alarmdecoder.com/wiki/index.php/Raspberry_Pi
This webapp will work with your PC browser as well as your phone/tablet browser. The notification system is also robust for alarm events.
Users browsing this forum: No registered users and 55 guests
