Vera Edge UI7 With AD2PI Over Ethernet
Postby ItchyRash » Tue Aug 18, 2015 5:50 pm
Hi, I followed every forum I could find on Alarm Decoder and micasaverde for getting AD2PI to work over ethernet using your AD2PI bundle. I loaded the app from the Install Apps panel in the Vera page. I followed the advice here on the two pinned forum posts and the two posts on micasaverde concerning using AD2PI over ethernet. I ran it straight from the app install, I uploaded the modified LUAs and never got anything to work. I'm ashamed to say that I've resorted to using the Envisalink plug in.
I'm hoping that these post were not for UI7 and that if I wait a while I can go back to using my AD2PI.
Is there straight forward instructions for getting this configuration to work? I'd really like to ditch the Envisalink and just use the AD2PI for everything.
Thanks for the help.
ItchyRash
Re: Vera Edge UI7 With AD2PI Over Ethernet
Postby kevin » Tue Aug 18, 2015 9:34 pm
Not sure how this works, I just know you can - I would contact Vera support and they should be able to get you squared away. I know several users of their forum are also using this configuration.
In the next week or so if I have time I will plug in our Vera and attempt this configuration and update.
I know in the past, you had to do this: viewtopic.php?f=3&t=111
But as far as I know, it is in the official driver now.
