API examples
API examples
Postby lucavista » Mon Oct 05, 2015 4:05 am
I'm looking at the python api but the examples available are very basic.
Is anywhere some example including sending messages (keypad numbers) and handling incoming messages?
lucavista
Re: API examples
Postby kevin » Mon Oct 05, 2015 9:54 am
https://github.com/nutechsoftware/alarm ... ialport.py is an example of handling a message
To send a message, you just call "device.send(string)" and if you want to verify the message actually sent to the panel you can use the "on_sending_received" event
#fake disarm
device.on_sending_received += handle_send
device.send(12341)
def handle_send(device, status, message):
    print "Successful alarm panel send"
Here is the API documentation: http://alarmdecoder.readthedocs.org/en/ ... rmdecoder/
You will see that a message has these properties:
raw = None
    The raw message text
timestamp = None
    The timestamp of the message
ready = False
    Indicates whether or not the panel is in a ready state.
armed_away = False
    Indicates whether or not the panel is armed away.
armed_home = False
    Indicates whether or not the panel is armed home.
backlight_on = False
    Indicates whether or not the keypad backlight is on.
programming_mode = False
    Indicates whether or not we’re in programming mode.
beeps = -1
    Number of beeps associated with a message.
zone_bypassed = False
    Indicates whether or not a zone is bypassed.
ac_power = False
    Indicates whether or not the panel is on AC power.
chime_on = False
    Indicates whether or not the chime is enabled.
alarm_event_occurred = False
    Indicates whether or not an alarm event has occurred.
alarm_sounding = False
    Indicates whether or not an alarm is sounding.
battery_low = False
    Indicates whether or not there is a low battery.
entry_delay_off = False
    Indicates whether or not the entry delay is enabled.
fire_alarm = False
    Indicates whether or not a fire alarm is sounding.
check_zone = False
    Indicates whether or not there are zones that require attention.
perimeter_only = False
    Indicates whether or not the perimeter is armed.
system_fault = False
    Indicates whether a system fault has occurred.
panel_type = 0
    Indicates which panel type was the source of this message.
numeric_code = None
    The numeric code associated with the message.
text = None
    The human-readable text to be displayed on the panel LCD.
cursor_location = -1
    Current cursor location on the keypad.
mask = 4294967295
    Address mask this message is intended for.
bitfield = None
    The bitfield associated with this message.
panel_data = None
    The panel data field associated with this message.
So you could access message.armed_away to see if your alarm is in an armed_away state in your handle_message routine
Re: API examples
Postby lucavista » Tue Oct 06, 2015 10:00 am
Thanks for the answer! I'm coding now :)
lucavista
