AD2PI - Can Receive but Can't Send
Postby B69CA » Wed Oct 28, 2015 11:37 am
Hi Guys,
Sorry if this has already been posted before. I have an AD2PI module which has been working flawlessly. However I was recently playing with sending data directly to the serial port and now seem to have an issue.
I seem to be able to receive data without an issue, I can see for example the panel status through ser2sock on port 10000.
My challenge however is that I no longer appear to be able to send. If I send a key, it seems to take a really long time and never actually seems to send.
Has anyone seen this before?
Cheers,
Jon
B69CA
Re: AD2PI - Can Receive but Can't Send
Postby kevin » Wed Oct 28, 2015 11:45 am
Make sure wiring didn't come loose
Make sure address didn't change
Make sure panel is capable of receiving on address ad2pi is set to
Postby B69CA » Wed Oct 28, 2015 11:53 am
Thanks Kevin,
It was indeed the address. Something seems strange too because each time I power off the device (the pi) and power it back on again it seems to loose the address. Is this normal?
Jon
B69CA
Postby kevin » Wed Oct 28, 2015 12:10 pm
No, that's not normal. How are you setting the address? Through web application or through direct serial access? If you are using a network appliance with the web application and are setting the configuration through direct serial access, the web application will override the settings with what is in its database.
Postby B69CA » Wed Oct 28, 2015 12:18 pm
I actually have always set it using the Alarm Decoder panel app for OS X. I will try with straight serial access and have a nosey to see if I can figure out what's going on.
Thanks for your help Kevin,
Jon
B69CA
Postby Scott » Wed Oct 28, 2015 3:00 pm
Are you using our raspbian image or did you build it up from scratch?
I've seen the settings get messed up if the serial console isn't disabled. Steps 3 & 4 under Manual Configuration in our wiki detail how to do that.
