ad2pi with homeseer
ad2pi with homeseer
Postby jcharles17 » Wed Mar 23, 2016 4:58 am
Has anyone got the ad2pi working with homeseer? I know there is not a plugin for it yet , only the ad2usb which I don't have.
Looking for a way to bring everything together with homeseer. Homeseer , It seems to be the best home automation controller so I think I'm thinking about buying it. Suggestions, advice?. Thank you very much for any help provided.
jcharles17
Re: ad2pi with homeseer
Postby Scott » Wed Mar 23, 2016 7:51 am
As far as I know Homeseer is closed source so the ideal option would be to get Mark to update his plugin. It should be a relatively simple change to support both sockets and COM ports.
An easier solution, albeit slightly more expensive, would be to run two AlarmDecoders: the AD2PI for the webapp and whatnot and an AD2USB attached to the Homeseer. You'd just need to configure a second keypad address for it.
Hope that helps!
Users browsing this forum: No registered users and 43 guests
