Notes on manual install of ser2sock on Pi3
Postby timlegge » Wed Apr 13, 2016 5:11 pm
Install latest raspbain jessie lite to your MicroSD as per the instructions on the Raspberry pi site:
Remap the pins to support serial console for ad2pi:
scp timlegge@remoteserver:/pi3-miniuart-bt-overlay.dtb ./
sudo cp pi3-miniuart-bt-overlay.dtb /
sudo vi /boot/config.txt
add the following to the end of the file
dtoverlay=pi3-miniuart-bt-overlay
force_turbo=1
sudo nano /lib/systemd/system/hciuart.service
Replace ttyAMA0 with ttyS0
I admit it Unicode and languages confuse me:
export LANGUAGE=en_US.UTF-8
export LANG=en_US.UTF-8
export LC_ALL=en_US.UTF-8
sudo locale-gen en_US.UTF-8
sudo dpkg-reconfigure locales
Apply updates and install requirements:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install libssl-dev telnet git
Clone the git repository and install:
git clone https://github.com/nutechsoftware/ser2sock.git
cd ser2sock/
./configure
make
sudo cp ser2sock /usr/local/bin/
sudo cp -R etc/ser2sock /etc/
sudo cp init/ser2sock /etc/init.d/
sudo update-rc.d ser2sock defaults
Configure ser2sock to run as the pi user:
sudo sed -i 's/^EXTRA_START_ARGS=.*$/EXTRA_START_ARGS=\"--chuid pi:dialout\"/g' /etc/init.d/ser2sock
Start daemon:
sudo /etc/init.d/ser2sock start
Testing:
Verify that you can connect to the ad2pi:
telnet 127.0.0.1 10000
Type a C and press enter <Enter>
You should see:
!CONFIG>ADDRESS=18&CONFIGBITS=0109&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
In addition at this point you should see messages from the panel that look familiar like: ****DISARMED**** Ready to Arm "
Repeat for the hostname: telnet alarmdecoder.local and you should get the same results
Test sending data to the Panel:
Via telnet you should be able to send data to the panel. Using the number keys send the code to arm or disarm - You must send each digit one at a time by pressing the enter key after each digit.
Troubleshooting:
If you are unable to send data to the panel to arm or disarm you likely do not have the key pad address enabled (Ademco Vista). You can verify on the Vista 20P by using a working panel:
1) enter programming mode
2) For keypad address 18 enter: #191
The keypad should report '01' or above (ie. not '00' which is disabled) followed by two digits signifying the sound
Tim
Reason: Sticky, change ser2conf to ser2sock in title
timlegge
Re: Notes on manual install of ser2conf on Pi3
Postby kevin » Wed Apr 13, 2016 5:34 pm
Just a note on the telnet bit - you don't have to press enter after every character, just every command - alarmdecoder buffers strings just fine, so 41121<enter> would work just the same. That said, if you enter "mode char" into telnet, you won't have to hit enter at all.
Postby timlegge » Wed Apr 13, 2016 5:41 pm
kevin wrote:Just a note on the telnet bit - you don't have to press enter after every character, just every command - alarmdecoder buffers strings just fine, so 41121<enter> would work just the same. That said, if you enter "mode char" into telnet, you won't have to hit enter at all.
Nice, I meant to try that but assumed that it would not work. That is much better.
timlegge
Re: Notes on manual install of ser2sock on Pi3
Postby David.B » Fri Dec 09, 2016 8:43 am
timlegge wrote:Install latest raspbain jessie lite to your MicroSD as per the instructions on the Raspberry pi site:
force_turbo=1
This section of the instructions (quoted above) is deprecated. Offically released overlays that come with jessie-lite are mentioned below...
Raspbian Jessie->lite as of today...
If you don't care about Bluetooth just turn it off to fix the ttyAMA0 issue....
edit /boot/config.txt  (use vi, nano...)
Add this line in:
dtoverlay=pi3-disable-bt
Disable HCI service:
systemctl disable hciuart
If you want to keep bluetooth...
Add this line in:
edit: /lib/systemd/system/hciuart.service
Modify the kernel boot params
Note these symbolic links...
lrwxrwxrwx 1 root root 7 Dec  9 08:50 /dev/serial0 -> ttyAMA0
lrwxrwxrwx 1 root root 5 Dec  9 08:50 /dev/serial1 -> ttyS0
Edit: /boot/cmdline.txt
Either remove the console=serialX part or change it to point to ttyS0 or serial1
Reboot after making the changes.
When testing the AD2Pi be sure to use the command "minicom -D /dev/ttyAMA0 -b115200"
When in minicom hit "=" to reboot the board, it will flash lights very fast then output some text showing you it's working.
ctrl-a, then X, exit without reset
David.B
Postby timlegge » Wed Nov 15, 2017 4:22 pm
Thanks for the updates on the new overlays etc. I finally got around to updating sersock and raspbian
timlegge
Postby wilsonb » Fri Nov 17, 2017 8:39 am
force_turbo=1
I don't have this
"Replace ttyAMA0 with ttyS0"
in mine. This is mine from the latest alarmdecoder image on Raspberry Pi A+
Mine;
[Unit]
Description=Configure Bluetooth Modems connected by UART
ConditionPathIsDirectory=/proc/device-tree/soc/gpio@7e200000/bt_pins
Before=bluetooth.service
After=dev-serial1.device
[Service]
Type=forking
ExecStart=/usr/bin/btuart
[Install]
WantedBy=multi-user.target
wilsonb
Postby timlegge » Fri Nov 17, 2017 6:49 pm
Mine too so I did not replace it in that file
timlegge
Postby onlize » Sun Sep 23, 2018 7:08 pm
I wanted to follow this guide, but problems started right away. I installed Raspbian Stretch. When I try to run:
it asks me about the password for timlegge@remoteserver. I am not sure what to do, but decided to change it to my user name and device name: pi@alarmdecoder. After I enter the password, I have this:
pi@alarmdecoder:~$ scp pi@alarmdecoder:/pi3-miniuart-bt-overlay.dtb ./
pi@alarmdecoder's password:
scp: /pi3-miniuart-bt-overlay.dtb: No such file or directory
pi@alarmdecoder:~$ sudo cp pi3-miniuart-bt-overlay.dtb /
cp: cannot stat 'pi3-miniuart-bt-overlay.dtb': No such file or directory
pi@alarmdecoder:~$
What should I do?
Thank you.
onlize
Users browsing this forum: No registered users and 2 guests
