Is it necessary to connect the red and black power leads from the alarm panel to the AD2PI if the Raspberry PI is getting power from a miniUSB connection?
A little background info... I tried first without the power connection from the panel, and while the green light on the AD2PI blinks every second and I can connect to the tty socket fine, any commands I send time out (5 dots on the send....., right?) and I see no messages from the system in the console. I've activated the key pad address I'm using with the installer code and set the AD2PI accordingly, so not sure what to check next...
Thanks for any help!
Matt
