[Solved] What is AD2USB (V2.2a.6) default configuration?
Postby jwings » Wed Feb 19, 2014 10:23 am
I just purchased a AD2USB and through trying to connect to it, I ended up changing some of the configuration. Can someone tell me what the default (factory) settings are? Below is the version I have and the present configuration. I think I corrected what was wrong, but not sure. I do have the AD2USB working, but I want to make sure I do not have something set incorrectly. Sorry if this info is posted someplace, but I could not find it. Thanks!
!Ademco Keypad Emulator V2.2a.6
!>Keypad Address (18) :>
!>Config Bits (ff00) :>
!>relay module #01 (N) :>
!>relay module #02 (N) :>
!>relay module #03 (N) :>
!>relay module #04 (N) :>
!>Address Filter Mask (afffffff) :>
!>Deduplicate (N) :>
!Reading configuration.
!UART init.
jwings
Re: What is AD2USB (V2.2a.6) default configuration?
Postby Scott » Wed Feb 19, 2014 10:32 am
Everything looks to be the default except for the address mask which is FFFFFFFF.
