Can't send, only receive on AD2USB from Vista 10SE
Postby tmoore » Tue Jun 27, 2017 7:12 am
Been trying to troubleshoot this myself but have hit a roadblock. I'm just trying to verify that I can send. I can see the panel results just fine but nothing I do seems to send anything, either using the keypad app or just using "screen". I'm using this on Linux, OS sees driver fine:
[ 69.386809] usbcore: registered new interface driver ftdi_sio
[ 69.387146] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 69.387231] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
[ 69.387332] usb 1-1: Detected FT-X
[ 69.387922] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
Device perms are ok as well (my personal user account is in group uucp, but I'm using sudo below)
crw-rw---- 1 root uucp 188, 0 Jun 27 11:09 /dev/ttyUSB0
Here's an example connection:
sudo screen -fn /dev/ttyUSB0 115200
Version:
!VER:ffffffff,V2.2a.8.2,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER
Config:
!CONFIG>MODE=A&CONFIGBITS=ff00&ADDRESS=31&LRR=N&COM=N&EXP=NNNNN&REL=NNNN&
(manual line break) MASK=ffffffff&DEDUPLICATE=N
!Reading configuration.
!UART init.
[01000001100000000A--],0fc,[f700000f10fc00002c020000000000],"COMM. FAILURE "
[01000001100000003A--],008,[f700000f1008000c2c020000000000],"ARMED ***AWAY***** ALL SECURE **"
***repeating***
- Entered @48 for debug
!>Diag. Flag (0) :>48
Configured for 10SE
!>Ademco/DSC Mode A/D (A) :>A
!>Keypad Address (31) :>
!>relay module #01 (N) :>
!>relay module #02 (N) :>
!>relay module #03 (N) :>
!>relay module #04 (N) :>
!>Emulate modem COM Y/N: (N) :>
!>Address Filter Mask (ffffffff) :>
!>Deduplicate (N) :>
!>Config Bits (ff00) :>
!UART init.
Typed in disarm code + 1 (seems to take 5 secs per key)
!Sending......done
!Sending......done
!Sending......done
!Sending......done
!Sending......done
***nothing changes***
Have tried just hitting *, no change
Any assistance would be appreciated!
tmoore
Re: Can't send, only receive on AD2USB from Vista 10SE
Postby kevin » Tue Jun 27, 2017 7:52 am
Please upgrade to the latest firmware and try again - if that fails, please email ad2usb@support.nutech.com
Postby tmoore » Tue Jun 27, 2017 8:33 am
Wow I feel stupid.. I thought 2.2a was the latest.. but then realized 8_2 vs 8_6
Thanks! I'll give it a shot.
tmoore
