[Solved] AD2USB problem
Postby marcino239 » Sun Mar 16, 2014 5:22 pm
I have AD2USB (hardware with the mini usb port) and upgraded to the firmware V2.2a.6 (V outputs: !VER:00000759,V2.2a.6,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB). However I cannot see standard console messages, only messages from the radio (example: !RFX*). Old software was displaying console messages ok, but after having trouble with alarmdecoder python package I've decided to upgrade to newer version to try if this will resolve the problem. All the keyboard have address 31, AD2USB is set to 30:
!>Keypad Address (30) :>
!>Config Bits (ff00) :>
!>relay module #01 (N) :>
!>relay module #02 (N) :>
!>relay module #03 (N) :>
!>relay module #04 (N) :>
!>Address Filter Mask (ffffffff) :>
!>Deduplicate (N) :>
!Reading configuration.
!UART init.
Appreciate your help.
Best Regards,
Marcin
marcino239
Re: AD2USB problem
Postby mathewss » Sun Mar 16, 2014 9:31 pm
Hay Marcin.
If your other keypads are at 31 and function correctly then you must have an SE panel. Set your Ad2* to address 31 and messages should start to show up and you will be able to ARM/DISARM etc.
