[Solved] AD2USB not communicating with my Vista 10p
Postby xuniman » Tue Apr 01, 2014 5:32 pm
I have set up the ad2usb and have i communicating to the laptop but it doesn't seem to communicate to the panel. I have enabled the *191 (address 18) keypad in the system but get no coms. The green light is blinking on he ad2usb.
Any ideas?
xuniman
Re: AD2USB not communicating with my Vista 10p
Postby mathewss » Tue Apr 01, 2014 5:41 pm
Lots but its not enough information.
Do you have any log output from the Alarmdecoder Keypad App? It should show your settings when it first starts up in the log and any messages from the panel it does see.
Postby xuniman » Tue Apr 01, 2014 6:21 pm
i just tells me it's waiting for first message
xuniman
Postby mathewss » Tue Apr 01, 2014 6:24 pm
Yaa.. um. thats not a log :) I need more than that. Select the LOG tab copy/paste all the text and paste it here inside of a <code> tag.
xuniman wrote:i just tells me it's waiting for first message
Postby xuniman » Tue Apr 01, 2014 6:32 pm
I did use PuTTY to verify that the ad2usb was talking to he PC. i went through all the configuration prompts an saw the correct info.
xuniman
Postby xuniman » Tue Apr 01, 2014 6:35 pm
Here it is
Starting AlarmDecoderApp build #2.0.10.40818
4/1/2014 7:33:41 PM Loding modules. To remove modules use the modules tab under the about menu
4/1/2014 7:33:41 PM Example V1.0 initialized
4/1/2014 7:33:41 PM keypad V1.0 initialized ()
4/1/2014 7:33:41 PM MyStuff V1.0b initialized
4/1/2014 7:33:47 PM Waiting for communication to AlarmDecoder to open
4/1/2014 7:33:47 PM Opening com port: 'COM2'
4/1/2014 7:33:47 PM Communicaiton to AlarmDecoder established
4/1/2014 7:33:47 PM Trying to make sure we are not in config mode sending \r\n A Bunch!
4/1/2014 7:33:50 PM Sending '\r\n' to check if in config mode.
4/1/2014 7:33:50 PM The AlarmDecoder not in config mode. Continuing to initialize.
4/1/2014 7:33:51 PM Sending 'V' command to the AlarmDecoder
4/1/2014 7:33:51 PM !VER:ffffffff,V2.2a.6,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB
4/1/2014 7:33:51 PM Found Version String
4/1/2014 7:33:52 PM Sending 'C' command to the AlarmDecoder
4/1/2014 7:33:52 PM !>
4/1/2014 7:33:52 PM !CONFIG>ADDRESS=18&CONFIGBITS=ff00&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
4/1/2014 7:33:52 PM Found and saving Config String
4/1/2014 7:33:53 PM Sending '\r\n' command to the AlarmDecoder
4/1/2014 7:33:54 PM !RFX:0331715,80
xuniman
Postby mathewss » Tue Apr 01, 2014 6:42 pm
Has anything else shown up after the last RFX message after several minutes?
Postby xuniman » Tue Apr 01, 2014 6:46 pm
Sorry, I didn't leave it plugged in. I have a short wire between the panel and the device. The one I originally had on was really long 9mybe 80 feet) so I took it out to remove a variable. I will go hook it back up and leave it running for 10 minutes or so.
xuniman
Postby xuniman » Tue Apr 01, 2014 7:43 pm
Attempt #2
4/1/2014 8:16:05 PM Loding modules. To remove modules use the modules tab under the about menu
4/1/2014 8:16:05 PM Example V1.0 initialized
4/1/2014 8:16:05 PM keypad V1.0 initialized ()
4/1/2014 8:16:05 PM MyStuff V1.0b initialized
4/1/2014 8:16:11 PM Waiting for communication to AlarmDecoder to open
4/1/2014 8:16:12 PM Opening com port: 'COM2'
4/1/2014 8:16:12 PM Communicaiton to AlarmDecoder established
4/1/2014 8:16:12 PM Trying to make sure we are not in config mode sending \r\n A Bunch!
4/1/2014 8:16:14 PM Sending '\r\n' to check if in config mode.
4/1/2014 8:16:15 PM The AlarmDecoder not in config mode. Continuing to initialize.
4/1/2014 8:16:16 PM Sending 'V' command to the AlarmDecoder
4/1/2014 8:16:16 PM !VER:ffffffff,V2.2a.6,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB
4/1/2014 8:16:16 PM Found Version String
4/1/2014 8:16:17 PM Sending 'C' command to the AlarmDecoder
4/1/2014 8:16:17 PM !>
4/1/2014 8:16:17 PM !CONFIG>ADDRESS=18&CONFIGBITS=ff00&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
4/1/2014 8:16:17 PM Found and saving Config String
4/1/2014 8:16:18 PM Sending '\r\n' command to the AlarmDecoder
4/1/2014 8:23:20 PM !RFX:0954754,80
4/1/2014 8:26:26 PM !RFX:1045830,84
4/1/2014 8:40:00 PM !RFX:0954754,80
4/1/2014 8:40:00 PM !EX> Item List changed name: 0954754 id: 954754
4/1/2014 8:41:20 PM !RFX:0954754,80
xuniman
Postby mathewss » Tue Apr 01, 2014 8:33 pm
Ok this is a head scratcher but I think its just a configuration issue. You mentioned you modified the programming to enable this keypad address are you sure its a P panel and not an SE panel that needs to be at address 31?
Please provide the following
1. AlarmDecoder model USB/SERIAL Etc.
2. Photo of your panel so I can see the wiring and model # stickers
3. Confirm the wiring is correct by watching the install video just in case the installer used the wrong colors etc compare with your panels model # wiring diagram usually located on the inside of the alarm panel enclosure
Seeing the RFX messages and no ALPHA messages seems very odd unless its an SE panel and needs to be changed to 31.
You may want to just use the GUI and change to 31 just to confirm if it works. Look at the new OSX video it shows how to change the address in the video to 31 for an SE panel.
