[Solved] Vista-20P - ECP Error / Open ckt
Postby devildog0331 » Wed Apr 16, 2014 8:26 pm
Hello all.
I'm having issues connecting my ad2usb ver 2 to my panel. The system without the ad2usb is functioning just fine but when I plug this in, I get an ECP ERROR on my 6280 and open ckt on my 6160rf.
The 6160rf is using address 16.
The 6280 is using address 1.
I also have two expanders.
The decoder is connected to a Mac running 10.8.5
i've tried address 17, 18, 19, and 20 (all open with 1 1 in the panel).
The below is a dump from the keypad app log (disconnected the green and yellow wires):
Starting AlarmDecoderApp build #2.0.10.23844
4/16/2014 11:16:22 PM Loding modules. To remove modules use the modules tab under the about menu
4/16/2014 11:16:22 PM Example V1.0 initialized
4/16/2014 11:16:22 PM keypad V1.0 initialized ()
4/16/2014 11:16:22 PM MyStuff V1.0b initialized
4/16/2014 11:16:32 PM Waiting for communication to AlarmDecoder to open
4/16/2014 11:16:32 PM Communicaiton to AlarmDecoder established
4/16/2014 11:16:32 PM Trying to make sure we are not in config mode sending \r\n A Bunch!
4/16/2014 11:16:36 PM 4/16/2014 11:16:36 PM Sending '\r\n' to check if in config mode.
4/16/2014 11:16:36 PM The AlarmDecoder not in config mode. Continuing to initialize.
4/16/2014 11:16:36 PM Sending 'V' command to the AlarmDecoder
4/16/2014 11:16:36 PM !VER:ffffffff,V2.2a.6,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB
4/16/2014 11:16:36 PM Found Version String
4/16/2014 11:16:37 PM Sending 'C' command to the AlarmDecoder
4/16/2014 11:16:37 PM !>
4/16/2014 11:16:37 PM !CONFIG>ADDRESS=20&CONFIGBITS=ff00&LRR=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
4/16/2014 11:16:37 PM Found and saving Config String
4/16/2014 11:16:39 PM Sending '\r\n' command to the AlarmDecoder
4/16/2014 11:16:49 PM !>Keypad Address (20) :
4/16/2014 11:16:49 PM >!>Config Bits (ff00) :
4/16/2014 11:16:49 PM >!WARNING. Do not enable a module if the physical module exists on the system.
4/16/2014 11:16:49 PM !Zone Expanders Y/N Max allowed: 02
4/16/2014 11:16:49 PM !>expander module #01 ZN 09-16 (N) :
4/16/2014 11:16:49 PM >!>expander module #02 ZN 17-24 (N) :
4/16/2014 11:16:49 PM >!>expander module #03 ZN 25-32 (N) :
4/16/2014 11:16:49 PM >!>expander module #04 ZN 33-40 (N) :
4/16/2014 11:16:49 PM >!>expander module #05 ZN 41-48 (N) :
4/16/2014 11:16:49 PM >!Relay Modules Y/N Max allowed: 04
4/16/2014 11:16:49 PM !>relay module #01 (N) :
4/16/2014 11:16:49 PM >!>relay module #02 (N) :
4/16/2014 11:16:49 PM >!>relay module #03 (N) :
4/16/2014 11:16:49 PM >!>relay module #04 (N) :
4/16/2014 11:16:49 PM >!>Emulate Long Range Radio Y/N: (N) :
4/16/2014 11:16:49 PM >!>Address Filter Mask (ffffffff) :
4/16/2014 11:16:49 PM >!>Deduplicate (N) :
4/16/2014 11:16:49 PM >!Reading configuration.
4/16/2014 11:16:49 PM !UART init.
4/16/2014 11:16:56 PM Restart application for settings to take effect
Thanks for the help!
devildog0331
Re: Vista-20P - ECP Error / Open ckt
Postby mathewss » Wed Apr 16, 2014 8:44 pm
The configuration looks good and with an ECP error I want to say its a wiring issue or the AD2* is faulty. Is this a new unit or was it working and then this happened?
Postby devildog0331 » Wed Apr 16, 2014 8:59 pm
i bought it a month or so ago and tried to use it along with your panel downloader (the panel and decoder was all bought at the same time) but i decided to just use the keypad to do it (similar issues)
i traced the wires back and the green wire is tied into the same bundle as my other keypads and ditto on the yellow. Green is routed to the DI and the yellow is on the DO.
voltage check: 13volts green to red / 13 volts yellow to white
speaking of power… I'm using an aux power supply on one of my keypads so i shouldn't be overloading my panel.
The wife and kids are sleeping so I'm limited now but will gladly check anything you can recommend tomorrow afternoon.
thanks.
devildog0331
Postby mathewss » Wed Apr 16, 2014 9:10 pm
devildog0331 wrote:i bought it a month or so ago and tried to use it along with your panel downloader (the panel and decoder was all bought at the same time) but i decided to just use the keypad to do it (similar issues)
thanks.
Ok I would like to run some tests over the phone but I am not sure on my schedule. Send me your contact data to general@support.nutech.com and lets find a time to do some testing. If it is a blown AD2* it wont be hard to figure out. If its that AUX power also not hard to figure out.
Postby devildog0331 » Fri Apr 18, 2014 8:55 am
Turned out to be a short that was easily fixed. Everything is now working how it should.
Thanks for the great support!
devildog0331
Users browsing this forum: No registered users and 16 guests
