Some EXP messages not captured
Postby jrussell05 » Sat Nov 18, 2017 5:08 pm
I have an AD2USB connected to a Vista 20P panel. I'm running the latest version of the Keypad App, 2.0.10. I also have the latest firmware, 2.2a.8.8 installed.
I'm trying to debug my setup with OpenHAB. I'm noticing from the log that some EXP messages don't get received. See the below:
11/18/2017 7:21:36 PM [10000001000000003A--],008,[f70000f71008001c08020000000000],"****DISARMED**** Ready to Arm "
11/18/2017 7:21:39 PM !EXP:09,02,01
11/18/2017 7:21:39 PM !EX> Item List changed name: 09 id: 409
11/18/2017 7:21:40 PM [00000001000000000A--],026,[f70000f71026000008020000000000],"FAULT 26 GARAGE ENTRY "
11/18/2017 7:21:43 PM [00000001000000000A--],025,[f70000f71025000008020000000000],"FAULT 25 GARAGE MOTION "
11/18/2017 7:21:47 PM [00000001000000000A--],026,[f70000f71026000008020000000000],"FAULT 26 GARAGE ENTRY "
11/18/2017 7:21:48 PM !EXP:09,01,00
11/18/2017 7:21:48 PM !EX> Item List changed name: 09 id: 409
11/18/2017 7:21:48 PM [10000001000000003A--],008,[f70000f71008001c08020000000000],"****DISARMED**** Ready to Arm "
As you can see, the EXP message "!EXP:09,02,01", which is the Garage Entry, gets picked up. However, the corresponding, "!EXP:09,02,00" message is missing. As well, there is no "!EXP:09,01,01" message for the Garage Motion, only the "!EXP:09,01,00" message saying that the zone is OK.
I also sometimes get "!EXP:09,05,02". I thought the only allowed values for the third set of digits was 01 and 00. The AlarmDecoder binding in OpenHAB won't parse the message with "02".
Here are my settings:
11/18/2017 7:13:07 PM Sending 'V' command to the AlarmDecoder
11/18/2017 7:13:07 PM !VER:ffffffff,V2.2a.8.8,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;L2;KE;M2;CB;DS;ER;CR
11/18/2017 7:13:07 PM Found Version String
11/18/2017 7:13:08 PM Sending 'C' command to the AlarmDecoder
11/18/2017 7:13:08 PM !>
11/18/2017 7:13:08 PM !CONFIG>MODE=A&CONFIGBITS=ff04&ADDRESS=18&LRR=N&COM=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
Any ideas?
jrussell05
Re: Some EXP messages not captured
Postby kevin » Mon Nov 20, 2017 3:20 pm
Does the raw stream (straight connection to device, not through some other service) have the data? If not, email support for firmware issues.
Postby jrussell05 » Tue Nov 21, 2017 7:27 am
Ok. I've connected the AD2USB directly to my Pi running OpenHAB. It appears the messages are getting through now. I don't have the raw output but the OpenHAB log shows the EXP zones opening and closing as expected.
Previously I had connected the AD2USB to my PC. I was running the Keypad App and serving the output through a socket connection to OpenHAB. Perhaps the problem lies in the Keypad App?
Ultimately having the AD2USB connected directly to the Pi is how I want to be running things. However, it makes debugging/development a bit more cumbersome.
jrussell05
Postby kevin » Tue Nov 21, 2017 8:17 am
Hooking directly to the pi is even easier to debug IMO. Just open the "serial port" once you shut down the services using it, and you can connect to the raw stream.
Postby jrussell05 » Tue Nov 21, 2017 7:18 pm
Ok. I'll give it a try.
Still getting the following message: !EXP:09,05,02. Why 02?
jrussell05
Postby kevin » Wed Nov 22, 2017 8:22 am
You'll have to email support to determine that one, can't help you with firmware here
Postby jrussell05 » Fri Nov 24, 2017 10:34 am
Thanks Kevin.
I did read the raw output from the serial port. Sometimes there is no !EXP:09,05,02 message, only the !EXP:09,05,00 message.
What is the email address for support. Can't seem to find it on your site.
thanks
jrussell05
Postby kevin » Fri Nov 24, 2017 8:43 pm
There is a contact link in the footer, ad2usb@support.nutech.com
