I am totally new to this alarmdecoder thing and raspberry Pi. Hello,
I just bought an Ad2Pi device and having some issue to get started.
My Setup: Honeywell Vista 15PSIA with one 6160 keypad at address 16, a CDMA alarm communicator connected to Alarm out terminals.
I am using your pre-configured image and verified wiring as per instructions. I also updated serial ports to
lrwxrwxrwx 1 root root 7 Dec 9 08:50 /dev/serial0 -> ttyAMA0
lrwxrwxrwx 1 root root 5 Dec 9 08:50 /dev/serial1 -> ttyS0
I can see the status from the panel on the web app and can see all the transaction messages on telnet. However, I am not able send any commands to the the panel (I cant arm, disarm) from the web app. During setup on web app, device testing fails as shown below
Opening device ✔
Saving device configuration ⚠ Test timed out.
Keypad communication (Send) ⚠ Test timed out.
Keypad communication (Receive) ✔
This is the diagnostic log from web app
rv = self.dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/flask_login.py", line 792, in decorated_view
return func(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/decorators.py", line 16, in decorated_function
return f(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/settings/views.py", line 717, in system_diagnostics
device_settings['serial'] = current_app.decoder.device.serial_number.upper()
AttributeError: 'long' object has no attribute 'up
! C or V command from terminal does not get any response.
Any pointers to troubleshoot this ?
regards
Safar
