WebApp on Raspberian stretch install problems
Postby trialnerror » Thu Jan 18, 2018 1:04 pm
Hi all, new to forum. Haven't touched *nix in 20+ years so basically a script kiddie trying to install the WebApp on a full version of Raspberian Stretch (Raspbian GNU/Linux 9). I was following the WebApp install directions at:https://github.com/nutechsoftware/alarmdecoder-webapp/blob/master/README.md and made it to step 8. The "make" failed with errors towards the end:
cc -c -pipe  -O -W -Wall -Wpointer-arith -Wno-unused -Werror -g  -I src/core -I src/event -I src/event/modules -I src/os/unix -I objs \
   -o objs/src/os/unix/ngx_linux_sendfile_chain.o \
   src/os/unix/ngx_linux_sendfile_chain.c
   -o objs/src/event/ngx_event_openssl.o \
   src/event/ngx_event_openssl.c
src/event/ngx_event_openssl.c: In function ‘ngx_ssl_init’:
src/event/ngx_event_openssl.c:110:5: error: ‘OPENSSL_config’ is deprecated [-Werror=deprecated-declarations]
     OPENSSL_config(NULL);
In file included from /usr/include/openssl/ct.h:13:0,
                 from /usr/include/openssl/ssl.h:61,
                 from src/event/ngx_event_openssl.h:15,
                 from src/core/ngx_core.h:73,
                 from src/event/ngx_event_openssl.c:9:
/usr/include/openssl/conf.h:92:1: note: declared here
 DEPRECATEDIN_1_1_0(void OPENSSL_config(const char *config_name))
src/event/ngx_event_openssl.c: In function ‘ngx_ssl_rsa512_key_callback’:
src/event/ngx_event_openssl.c:672:9: error: ‘RSA_generate_key’ is deprecated [-Werror=deprecated-declarations]
         key = RSA_generate_key(512, RSA_F4, NULL, NULL);
In file included from /usr/include/openssl/rsa.h:13:0,
                 from /usr/include/openssl/x509.h:31,
                 from /usr/include/openssl/ssl.h:50,
/usr/include/openssl/rsa.h:193:1: note: declared here
 DEPRECATEDIN_0_9_8(RSA *RSA_generate_key(int bits, unsigned long e, void
src/event/ngx_event_openssl.c: In function ‘ngx_ssl_dhparam’:
src/event/ngx_event_openssl.c:862:11: error: dereferencing pointer to incomplete type ‘DH {aka struct dh_st}’
         dh->p = BN_bin2bn(dh1024_p, sizeof(dh1024_p), NULL);
src/event/ngx_event_openssl.c: In function ‘ngx_ssl_handshake’:
src/event/ngx_event_openssl.c:1081:31: error: dereferencing pointer to incomplete type ‘SSL {aka struct ssl_st}’
         if (c->ssl->connection->s3) {
src/event/ngx_event_openssl.c: In function ‘ngx_ssl_connection_error’:
src/event/ngx_event_openssl.c:1817:21: error: ‘SSL_R_NO_CIPHERS_PASSED’ undeclared (first use in this function)
             || n == SSL_R_NO_CIPHERS_PASSED                          /*  182 */
src/event/ngx_event_openssl.c:1817:21: note: each undeclared identifier is reported only once for each function it appears in
src/event/ngx_event_openssl.c: In function ‘ngx_ssl_session_cache’:
src/event/ngx_event_openssl.c:2006:43: error: passing argument 2 of ‘SSL_CTX_sess_set_get_cb’ from incompatible pointer type [-Werror=incompatible-pointer-types]
         SSL_CTX_sess_set_get_cb(ssl->ctx, ngx_ssl_get_cached_session);
In file included from src/event/ngx_event_openssl.h:15:0,
/usr/include/openssl/ssl.h:637:6: note: expected ‘SSL_SESSION * (*)(struct ssl_st *, const unsigned char *, int,  int *) {aka struct ssl_session_st * (*)(struct ssl_st *, const unsigned char *, int,  int *)}’ but argument is of type ‘SSL_SESSION * (*)(SSL *, u_char *, int,  int *) {aka struct ssl_session_st * (*)(struct ssl_st *, unsigned char *, int,  int *)}’
 void SSL_CTX_sess_set_get_cb(SSL_CTX *ctx,
src/event/ngx_event_openssl.c: In function ‘ngx_ssl_session_ticket_key_callback’:
src/event/ngx_event_openssl.c:2673:9: error: ‘RAND_pseudo_bytes’ is deprecated [-Werror=deprecated-declarations]
         RAND_pseudo_bytes(iv, 16);
In file included from /usr/include/openssl/engine.h:19:0,
                 from src/event/ngx_event_openssl.h:22,
/usr/include/openssl/rand.h:47:1: note: declared here
 DEPRECATEDIN_1_1_0(int RAND_pseudo_bytes(unsigned char *buf, int num))
cc1: all warnings being treated as errors
objs/Makefile:767: recipe for target 'objs/src/event/ngx_event_openssl.o' failed
make[1]: *** [objs/src/event/ngx_event_openssl.o] Error 1
make[1]: Leaving directory '/home/pi/nginx-1.7.4'
Makefile:8: recipe for target 'build' failed
make: *** [build] Error 2
Suggestions? If not updated code, can the deprications be force-accepted with a modification of the make file and some switch on the cc calls? Use an earlier version of Raspberian? I'm trying to install the WebApp on a machine that will be exposed if only slightly to the Internet, and didn't want that to be the AD2PI's WebApp instance (which should be shipping to me soon). Thanks again for any help.
trialnerror
Re: WebApp on Raspberian stretch install problems
Postby kevin » Sun Jan 21, 2018 10:04 pm
looks like openssl-dev is not installed also maybe use a newer version of nginx
Postby trialnerror » Wed Jan 24, 2018 7:38 pm
Thanks. Alarmdecoder ad2pi just arrived in the mail so rather than futzing with this I went with the stock factory image. Just finished wiring it to the panel and at first blush it just works. That's the goal. Hope to kick the tires more this weekend. Really glad you guys made this product.
trialnerror
