AD2PI + Vista 15P able to receive, but not send
Postby louieo » Sun Jan 21, 2018 9:56 pm
I just got the AD2PI and have been configuring it. I have a problem, where I can receive messages and get it displayed in my browser, but not send commands to the Vista 15P.
Here is my current configuration:
Honeywell Vista 15P
- Keypad addresses 18-23 all set to allow a keypad to be addressed (*19x, 10 - where X=1..6)
- Physical keypad is configured in address 17
AD2PI configured in address 18 (*191, 10)
- Firmware - 2.2a.8.8
Raspberry PI model: 3B
- Using the current Raspbian Jessie Lite image from the website, copied onto the flash drive using Win32DiskImager
- Webapp has been updated via the Web interface
/boot/config.txt:
dtoverlay=pi3-miniuart-bt
/dev/serial* output:
lrwxrwxrwx 1 root root 7 Jul 24 04:23 serial0 -> ttyAMA0
lrwxrwxrwx 1 root root 5 Jul 24 04:23 serial1 -> ttyS0
ser2sock is working, I can telnet to it at port 10000 from another PC
"C" output
!CONFIG>MODE=A&CONFIGBITS=ff00&ADDRESS=18&LRR=N&COM=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
"V" output
!VER:ffffffff,V2.2a.8.8,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;L2;KE;M2;CB;DS;ER;CR
In the Web interface, I went to Settings->Advanced->Start->Device Type (all default settings)->Local Device settings (all default; used /dev/serial0, 115200 baud)->Network Host Settings (all default)->Alarm Decoder Settings (all default; used Honeywell/Ademco, address 18, everything else is default)
Output:
Device Testing
Opening device OK
Saving device configuration OK
Keypad communication (Send) Check wiring and that the correct keypad address is being used.
Keypad communication (Receive) OK
Other things I've done which did not change the result:
- Confirmed wire continuity, swapped wires D1 & D0 (which resulted in both keypad send/receive timing out, so I swapped it back), swapped wires with new wires
- Swapped Raspberry Pi's with a model 2
- Used different keypad addresses (19..23)
Is there anything else I can look into?
louieo
Re: AD2PI + Vista 15P able to receive, but not send
Postby kevin » Sun Jan 21, 2018 10:00 pm
Please email support at ad2usb@support.nutech.com
Postby ggfrank21 » Fri Feb 09, 2018 3:03 pm
have you received a solution yet? i have the same issue with a Vista 20P. I am a Install Tech so i have checked and replaced wires and configuration and still i received but can not send to the BA
ggfrank21
Postby louieo » Sat Feb 10, 2018 11:15 am
Hi, I went through the triage and ended up going through the RMA exchange.
- wires changed with new ones
- used different addresses for the keypad (18, 19, ...) all of which were configured as enabled on the panel
- DI/DO switched to see if that was the issue (which resulted in both sending/receiving not working, so I put it back to the correct order)
- changed raspberry PI
- changed AD2PI firmware to the beta version and enabled debugging to provide additional info
Ultimately I tried removing the raspberry PI+AD2PI, and connected an identical keypad. That 2nd keypad worked, I can send/receive signals from the panel.
louieo
Postby rick505 » Sun Feb 11, 2018 1:38 pm
I'm at that point. Mine is the opposite:
Device Testing
Opening device OK
Keypad communication (Send) OK
Keypad communication (Receive) Failed
emailed and never received anything back other than ticket number. At the point of requesting refund and trying another solution.
Rick
rick505
Postby ggfrank21 » Sun Feb 11, 2018 5:18 pm
i figured out my problem and it sounds like it my be yours as well. On the alarms KP get into programming and address 18 by hitting *191 then (2). it will chime then *99 out of programming
ggfrank21
Postby louieo » Mon Feb 12, 2018 12:22 pm
That parameter works for the Vista 20P (it selects partition 2). I also tried this on my Vista 15P as part of my troubleshooting, which did not take this command.
louieo
Postby louieo » Fri Feb 16, 2018 5:38 pm
Hi, I just wanted to give an update... I received my replacement unit and have installed it just now. I am now able to send & receive msgs on my AD2PI (I was only able to receive msgs on the previous unit)
I ran the setup in the browser interface, and the final window where the diagnostics are would now show up as "ok" for all functions.
louieo
Users browsing this forum: No registered users and 57 guests
