Get Panel and Scan Panel for Zone's is not working... Very 1st set-up worked, but had to reset DB. Now unable to "Get Panel" or "Scan Panel" -
Panel is a VISTA 15PSIA
Error: 2018-02-03 12:51:08,950 ERROR: default_error_handler: method_access_denied, You do not have access to method "recv_disconnect" (endpoint=/alarmdecoder, msg_id=None) [in /usr/local/lib/python2.7/dist-packages/socketio/virtsocket.py:51]
If I Get or Scan during power on cycle, some info is collected but not all.
Other than that, the keypad functions and the webapp is logging alarm activity. Diagnostics, also give all green checks.
Thanks for any help. 1st time Pi and AD User.
