SmartThings API Doesn't Discover Device
Postby BravoCharlie » Sun Mar 11, 2018 10:51 am
Trying to integrate my AD2Pi Network Appliance with SmartThings using the Readme at https://github.com/nutechsoftware/alarm ... martthings
I get down to:
Install SmartApp...Click the Discover button. You'll probably have to hit refresh a couple of times to get your device to show up. If it doesn't show up make sure you're running an up-to-date version of the webapp.
I get: Select device(s) (0 found). Clicking Refresh is not helping. I have WebApp v0.8.0-8-g57438d1. I tried Googling and came up empty. I deleted what had been accomplished in the API under SmartApps up to that point and tried again with the same result.
Unfortunately, my "expertise" ends there. :( Any ideas or would this be better addressed with the SmartThings community?
Bob
BravoCharlie
Re: SmartThings API Doesn't Discover Device
Postby kevin » Sun Mar 11, 2018 4:46 pm
Look at the logs on the pi in /opt/alarmdecoder-webapp/instance/ and /var/log/gunicorn.d and see if the discovery thread started ok.. also make sure you have support for upnp
Postby BravoCharlie » Mon Mar 12, 2018 1:21 pm
It was the UPNP.
Thx,
Bob
BravoCharlie
Postby grayzweb » Fri Aug 30, 2019 9:28 am
BravoCharlie wrote:It was the UPNP.
Thx,
Bob
I'm having same problem. I checked router and UPNP is enabled. What else can I check?
grayzweb
Postby grayzweb » Sat Aug 31, 2019 3:51 am
kevin wrote:Look at the logs on the pi in /opt/alarmdecoder-webapp/instance/ and /var/log/gunicorn.d and see if the discovery thread started ok.. also make sure you have support for upnp
I searched event logs in AlarmDecoder web app and could not find either of these entries. ?
grayzweb
